help for selecting Arduino hardware and interface
Hai...All..
I want to design a Unmanned vehicle based on Arduino board for below specification...
  1. Inter face with object sensing for obstacle avoidance
  2. Shaft encoder interface for distance measurement.
  3. Boot loader with wireless option
please sugest me which Arduino board supports and other interface blocks...
Hai...All..
I want to design a UGV ( Unmanned ground vehicle) based on Arduino board for below specification...
  1. Programming as per requiremtns..
  2. Inter face with object sensing for obstacle avoidance
  3. Shaft encoder interface for distance measurement.
  4. Boot loader with wireless option
  5. necessary complete kit for development...and assembly
    please sugest me to prepare a complete list of configuaration around Arduino and other interface blocks...
You are essentially asking others to design your project for you. What have you done so far on "your" project? If you expect others to design your project for you (which will require a lot of time and effort), how much $$$ are you willing to pay to have it done for you? The board generally helps others with their projects, but you may not get much help requesting a "turnkey" solution for your project design.
I think you understod in other way.....
I am only interested in knowing which type of Arduino board is suitable for the purpose......since iam confused with different verity of boards......
I have already prepared the gound work....only i am in search of suitable hardware interfcae units readyly available....
so that programming can be started as per my plan...
Thank you very much for the concern...... :slight_smile:
The mega below has the most features, but some "shields" may not match its pinouts if shields are required for your project. If shields are not an issue, then you would probably want the mega.
