circat
November 19, 2017, 2:13pm
#1
Hey Guys ,
im stuck on a problem with my Neopixel Wireless MIDI Code and hope you`ve a hint for me.
The Problem is simple :
If there is NO Serial Data / MIDI Data on RX of Arduino , do a thing ( Neopixel fading etc ) ,
if there`s Data use the MIDI Callbacks.
Tried everything with “If” or “while” statements but im confused now.
Do I need a time counter if there is NO serial for lets say 20 seconds?
Here`s my Code in Attachement and thank you
_191117_Keplermaske_MIDI_18.ino (10.9 KB)
This sounds like a job for millis() timing so that the input can be checked for a period.
Have a look at url=http://forum.arduino.cc/index.php?topic=503368.0]Using millis() for timing. A beginners guide[/url], Several things at the same time and look at the BlinkWithoutDelay example in the IDE.
circat
November 20, 2017, 8:27am
#3
Thank you ,
the millis() is a good idea , i`ll give it a try
but i dont know how to get the “serial” data check to work.
i tried “if serial read” , but this wont work.
possibly i should check IF THERE´s a MIDI byte available rather then if there`s pure serial data.
but how ? :o
here is my code in the void loop…
Serial.begin(9600); //XBEE
if (Serial.read == 0){
rainbowCycle(20); /NEOPIXEL
if(Serial.read > 0 ){
MIDI.setHandleControlChange(HandleControlChange);
MIDI.setHandleNoteOn(HandleNoteOn);
MIDI.setHandleNoteOff(HandleNoteOff);
MIDI.setHandleProgramChange(handleProgramChange);
PIXSTRIP.show();
RING.show();
Have a look at the Serial.available() function. If no data is available then do thing 1 else do thing 2
circat
November 20, 2017, 8:56am
#5
tried several times, but nothing worked..
if (Serial.available == 0){
is correct ?
circat:
is correct ?
No
That is not how you call a function
