Help for Ultrasonic Module HC-SR04 controlling Relay
Hello, I have a little Problem with my sketch the Relay didn´t go on.
Does anybody have an answer for this problem?
Here is my sketch:
long duration, distance;
#define trigPin 13
#define echoPin 12
#define led 11
#define led2 10
#define RELAY_ON 0
#define RELAY_OFF 1
#define Relay_1 38
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
digitalWrite(Relay_1, RELAY_OFF); // Relay 16
pinMode(Relay_1, OUTPUT); // Relay 16
digitalWrite(trigPin, LOW); // Added this line
delayMicroseconds(2); // Added this line
digitalWrite(trigPin, HIGH);
// delayMicroseconds(1000); - Removed this line
delayMicroseconds(10); // Added this line
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance < 4) { // This is where the LED On/Off happens
digitalWrite(led,HIGH); // When the Red condition is met, the Green LED should turn off
digitalWrite(led2,LOW);
else {
digitalWrite(led,LOW);
digitalWrite(led2,HIGH);
if (distance >= 200 || distance <= 0){
Serial.println("Out of range");
else {
Serial.print(distance);
Serial.println(" cm");
void Relais1() {
if ( distance <=20 )
digitalWrite(Relay_1, RELAY_ON);
When you add some serial prints to debug your problem, are you getting measurement data from the sensor?
Looks like you have both global and local variables for:
duration, distance;
Edit:
void Relais1() { // <<<< this will access the global variable but your calculation is done on the local variable.
Ok it work thank you very much for your help.
best regards
