Help for understand the operation of the circuit
Γεια σε ολους μπορει καποιος να με βοηθησει με την λειτουργια του παρακατω κυκλωματος ? Το ολοκληρωμενο D5 ειναι schmitt triger . Ποτε θα εχω στο πιν 1 κατασταση high και ποτε low ?
Google translate:
Hello everyone, can someone help me with the operation of the following circuit? The complete D5 is a schmitt trigger. When will I have a high status on pin 1 and when will it be low?
We seem to be missing something(s).
Please read the forum guidelines to get some ideas of the information that we need in order to answer questions.
πως μπορω να ανεβασω σχημα ? μπερδευτηκα
sorry how can i upload the schematic
i confused
schematic.help
The +24V supply forward biases the first bipolar transistor through R1. This wil turn ON the first transistor.
That first transistor will sink current through R3, turning OFF the second transistor. R5 will pull the input (pin 1) of the scmidt trigger to a HIGH state. The out ut of the gate will go low.
I presume the scmidt rigger gate is 4000 series CMOS as that can operate on 15V.
thanks a lot for the answer sir
so in this situation the input of schmitt triger is always high right ?
In whats case the input will be low ?
on th above circuit the led will open continously right ?
The LED is backwards and hee are no ground connections. The circuit will never work.
