[Help] Function pointer & lambda function
Hi, i have trouble with function pointer & lambda function.
The pointer cannot point to class’ function nor lamba function with capture.
can you fix my code below?
typedef void(*MyHandler)();
void target1() {
MyHandler h1 = target1; // <== works
class testClass {
public:
	void test() {
		MyHandler h2 = targert2; // <== compile error
	void targert2() {
	void testLambda() {
		MyHandler h3 = []() { // <== works
			// do something
		MyHandler h4 = [this]() { // <== compile error
			// do something
You cannot use a class member as a function pointer as you do. MyHandler needs to be something like "typedef void(testClass::*MyHandler)()" for that to work.
EDIT: Try to look at this.
