HELP!! Game w/ Shift Register
Here's the first half of the code:
int btnPin = 2;    // Digital 2 ; 'Toggle' Button
int irPin = 3;     // Digital 3 ; IR Detector
int bryPin = 5;   // Digital 5 ; Bottom Right Yellow LED
int trgPin = 6;   // Digital 6 ; Top Right Green LED
int blgPin = 7;   // Digital 7 ; Bottom Left Green LED
int tlyPin = 8;   // Digital 8 ; Top Left Yellow LED
int clockPin = 13; // Digital 9 ; SH_CP on Shift Register
int latchPin = 4; // Digital 10 ; ST_CP on Shift Register
int dataPin = 12;    // Digital 11 ; DATA on Shift register
int blPin = 10;    // Digital (PWM) 9 ; Red RGB LED
int cdsPin = 2;   // Analog 2 ; CdS Cell
int rdPin = 9;    // Digital (PWM) 10 ; Blue RGB LED
int gnPin = 11;    // Digital (PWM) 11 ; Green RGB LED
int irval = 1;
int btnval = 1;
int cdsval = 0;
int pos = 0;
int i = 0;;
int b;
int mdl = false;
int prev = 0;
int time = 0;
  time = 25;                  // How fast the pattern will go
  pinMode(latchPin, OUTPUT);
  pinMode(btnPin, INPUT);
  //pinMode(irPin, INPUT);
  pinMode(bryPin, OUTPUT);
  pinMode(trgPin, OUTPUT);
  pinMode(tlyPin, OUTPUT);
  pinMode(blPin, OUTPUT);
  pinMode(rdPin, OUTPUT);
  pinMode(gnPin, OUTPUT);
  clearLCD();
  Serial.print(0xFE, BYTE);
  Serial.print(0x0C, BYTE);
  determineBacklight();
  delay(100);
  selectLineOne();
  delay(100);
  Serial.print("Main Menu");
  for(i = 0; i < 10; i++) {     // Fancy stuff
    scrollLeft();
    delay(100);
  clearLCD();
  pos = 130;
  selectLineCustom();
  Serial.print("Select Menu");
  pos = 197;
  selectLineCustom();
  Serial.print("Option");
  delay(700);
  for(i = 0; i < 15; i++) {    // More fancy stuff
    scrollLeft();
    delay(100);
  clearLCD();
  mainMenu();
void selectLineOne(){  //puts the cursor at line 0 char 0.
   Serial.print(0xFE, BYTE);   //command flag
   Serial.print(128, BYTE);    //position
void selectLineTwo(){  //puts the cursor at line 0 char 0.
   Serial.print(192, BYTE);    //position
void selectLineCustom() {
   Serial.print(pos, BYTE);
   pos = 0;
void scrollRight() {
  Serial.print(0x1C, BYTE);
void scrollLeft() {
  Serial.print(0x18, BYTE);
void clearLCD(){
   Serial.print(0x01, BYTE);   //clear command.
void determineBacklight() {
  cdsval = analogRead(cdsPin);
  if(cdsval < 500) {
    backlightOn();
  else if(cdsval > 500) {
    backlightOff();
void backlightOn(){  //turns on the backlight
    Serial.print(0x7C, BYTE);   //command flag for backlight stuff
    Serial.print(157, BYTE);    //light level.
void backlightOff(){  //turns off the backlight
    Serial.print(128, BYTE);     //light level for off.
void serCommand(){   //a general function to call the command flag for issuing all other commands
void End() {                // I use this for debugging
  End();
void mainMenu() {
  Serial.print("Press toggle to switch options");
  delay(2000);
  clearLCD();
  Serial.print("Press select to select an option");
  delay(2000);
  clearLCD();
  Serial.print("Light-Stopper");
  option1();
void option1() {                // This keeps the LCD at the menu option "Light Stopper
    pinMode(irPin, INPUT);      // until a button on the remote or 'toggle' is pressed
    delay(100);
    irval = digitalRead(irPin);
    btnval = digitalRead(btnPin);
    if(irval == 0 && btnval == 0) {
      clearLCD();
      Serial.print("??");
    else if(irval == 0 && btnval == 1) {
      clearLCD();
      lightStopper();
    else if(irval == 1 && btnval == 0) {
      clearLCD();
      Serial.print("Simon");
      option2();
    else if(irval == 1 && btnval == 1) {
      option1();
void option2() {                            // ...And this one keeps it at "Simon"
    pinMode(irPin, INPUT);                  // menu option until a button is presses
    delay(100);
      Serial.print("??");
      clearLCD();
      Simon();
      clearLCD();
      option1();
      option2();
void Simon() {                              // (still haven't gotten to this yet...
  Serial.print("Under Construction!");
  Simon();
