Help getting SD card to read
Hey I am trying to modify some code written for a geiger counter to use with my arduino, the ethernet shield, and the RTC from adafruit. I'm having trouble getting the SD card to read though, could anyone go through the code and see what I did wrong?
#include <FreqCounter.h>  //FREQ
#include <Wire.h>         //For RTC
#include "RTClib.h"        //For RTC
RTC_DS1307 RTC;            //For RTC
#include <SD.h>            //For log
#include <SPI.h>
int chipSelect = 10;
File myFile;
//Start Serial
 Serial.begin(9600);                    // connect to the serial port
 Serial.println("Frequency Counter");
//Start RTC
 Wire.begin();
 RTC.begin();
 if (! RTC.isrunning()) {
   Serial.println("RTC is NOT running!");}
 if (RTC.isrunning()){
   Serial.println("RTC is running");}
//Check SD
 Serial.print("Initializing SD card...");
 // see if the card is present and can be initialized:
 if (!SD.begin(chipSelect)) {
   pinMode(10, OUTPUT);
   Serial.println("Card failed, or not present");
   digitalWrite(2, HIGH);   // set the LED on
   digitalWrite(3, LOW);   // set the LED off
   return;
 Serial.println("card initialized.");
//Prep File
 //file open
 myFile = SD.open("test.txt", FILE_WRITE);
 //write to it:
 if (myFile) {
   Serial.print("Writing to test.txt...");
   myFile.println("timestamp,date,time, cps,");
   //note consistant data structure here
   //timestamp, date, time, cps<frq>
  // close the file:
   myFile.close();
   Serial.println("ready.");
long int cpm;
long int frq;
///FREQ Counter components
   FreqCounter::f_comp= 10;    // Set compensation to 12
//////////////////////IMPORTANT CHANGE INTERVAL FOR READINGS HERE///////////////
   FreqCounter::start(60000);   // Start counting with gatetime of 1000ms
   while (FreqCounter::f_ready == 0)         // wait until counter ready
   frq=FreqCounter::f_freq;            // read result
   Serial.print("cps:");
   Serial.println(frq);                // print result
///RTC components
   DateTime now = RTC.now();
   Serial.print(now.year(), DEC);
   Serial.print('/');
   Serial.print(now.month(), DEC);
   Serial.print('/');
   Serial.print(now.day(), DEC);
   Serial.print(' ');
   Serial.print(now.hour(), DEC);
   Serial.print(':');
   Serial.print(now.minute(), DEC);
   Serial.print(':');
   Serial.print(now.second(), DEC);
   Serial.print(':');
   Serial.print("gmt");
///SAFETY
// use the LEDS for warning !!
//2CPS=117CPM=1.02µSv/hr=24.65µSv/dy=9000µSv/yr 9mSv/yr Airline safe dose
if (frq <= 11)  //11Cps=649cpm=5.70µSv/hr=136.98µSv/dy=50000µSv/yr 50mSv/yr Nuclear Worker Limit
  digitalWrite(3, HIGH);
  digitalWrite(2, LOW);
 else if (frq >11 && frq <= 22) //22Cps=1305cpm=11.415µSv/hr=273.96µSv/dy=100000µSv/yr 100000mSv/yr Threshold for detectable cancer risk
 else if (frq > 22) //
///2=RED 3=GREEN
/// Logging
//file open
 //write to it:
  if (myFile) {
    Serial.print("logging...");
    myFile.print(now.unixtime());
    myFile.print(',');
    myFile.print(now.year(), DEC);
    myFile.print('/');
    myFile.print(now.month(), DEC);
    myFile.print('/');
    myFile.print(now.day(), DEC);
    myFile.print(',');
    myFile.print(now.hour(), DEC);
    myFile.print(':');
    myFile.print(now.minute(), DEC);
    myFile.print(':');
    myFile.print(now.second(), DEC);
    myFile.print(':');
    myFile.print("gmt");
    myFile.print(',');
    myFile.println(frq);
   // close the file:
    myFile.close();
    Serial.println("done");
//int chipSelect = 10;
int chipSelect = 4;
The ethernet module uses pin 10 as chip select for the w5100 ethernet chip. chipSelect for the SD card reader is 4. Your setup can explicitly turn off the ethernet chip if you are not using it.
//Start Serial
//Start RTC
 Wire.begin();
 RTC.begin();
//Check SD
//ethernet not active
digitalWrite(10,HIGH);
   //pinMode(10, OUTPUT);
   return;
//Prep File
 //file open
 //write to it:
 if (myFile) {
  // close the file:
   myFile.close();
There's more information here SD examples and chip select definition - #3 by fat16lib - Storage - Arduino Forum
Thanks I solved the problem, it was hardware related
