Help. Have no idea of what problem is.
Yesterday i just wrote a simple code based on ReadWrite example on SD library and everything was working fine. i run the program more than 50 times and it worked
Today when i try to run the program again this simple doesnt work and i just get trash on serial monitor.
I already formated the SD Card and wrote the same .txt files than i need, i already check all the connections and everything is fine.
the best thing is that i run the ReadWrite example and i get it correctly. im really mind blowing with this. help pls.
in attachments a print of serie monitor.
Im using the standard SD library. The example is working and i can’t find the problem.
Here is my code:
#include <SPI.h>
#include <SD.h>
File myFile;
File myFile2;
char settings[2][10];
int y = 0;
char val[20];
int i = 0;
int player_id = 1;
int n_game = 3;
int n_button = 1;
int n_plays = 10;
unsigned long ltime = 100;
void setup(){
  while (!Serial) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  // re-open the file for reading:
  myFile = SD.open("settings.txt", FILE_READ);
  if (myFile) {
    Serial.println("settings.txt:");
    for(y = 0; y < 2; y++){
      i=0;
      while(val[i-1]!='\r'){
      val[i]=myFile.read();
      i++;
      strcpy(settings[y], val);
    myFile.close();
    Serial.println("error opening settings.txt");
  for(y = 0; y < 4; y++){
    Serial.print(settings[y]);
  myFile2 = SD.open("history.txt", FILE_WRITE);
  if (myFile2) {
    for(y = 0; y < n_plays; y++)
      if(y == 0){
        myFile2.print(player_id);
        myFile2.print("-");
        myFile2.print(n_game);
        myFile2.print(" ");
        Serial.print(player_id);
        Serial.print("-");
        Serial.print(n_game);
        Serial.print(" ");
      else if((y > 0) && (y < (n_plays-1))){
        myFile2.print(n_button);
        myFile2.print(".");
        myFile2.print(ltime);
        myFile2.print(" ");
        Serial.print(n_button);
        Serial.print(".");
        Serial.print(ltime);
        Serial.print(" ");
      else {
        myFile2.print(".");
        myFile2.println(ltime);
        Serial.print(".");
        Serial.println(ltime);
      ltime = ltime*2;
    Serial.println("History Saved!");
    myFile2.close();
    Serial.println("error opening history.txt");
  // nothing happens after setup
Instead of open the settings.txt file i open the test.txt created on the example and it works.
why can’t i open the settings.txt file that simply contains “5 10”?
gezuz:
Here is my code:
#include <SPI.h>
#include <SD.h>
File myFile;
File myFile2;
int y = 0;
char val[20];
int i = 0;
int player_id = 1;
int n_game = 3;
int n_button = 1;
int n_plays = 10;
void setup(){
  while (!Serial) {
  Serial.print(“Initializing SD card…”);
if (!SD.begin(4)) {
    Serial.println(“initialization failed!”);
    return;
  Serial.println(“initialization done.”);
  myFile = SD.open(“settings.txt”, FILE_READ);
  if (myFile) {
    Serial.println(“settings.txt:”);
      i=0;
      while(val[i-1]!=’\r’){
      i++;
    myFile.close();
    Serial.println(“error opening settings.txt”);
myFile2 = SD.open(“history.txt”, FILE_WRITE);
  if (myFile2) {
      if(y == 0){
        myFile2.print("-");
        myFile2.print(" “);
        Serial.print(”-");
        Serial.print(" “);
        myFile2.print(”.");
        myFile2.print(" “);
        Serial.print(”.");
        Serial.print(" “);
      else {
        myFile2.print(”.");
        Serial.print(".");
ltime = ltime*2;
Serial.println(“History Saved!”);
    myFile2.close();
    Serial.println(“error opening history.txt”);
well, i just left a empty line at the end of the .txt and its working...
      i=0;
      i++;
You compare the value in val[i - 1] before you write to val[ i ] and increment i. What IS in val[i - 1] at that point?
After reading a record, you never re-initialize val.
