Please... I need to measure the voltage of a 12 V battery via analog input 1 of the Arduino Nano board. My Arduino board is powered by a 5V ( the range is from 3.3 V to 6 V ). I found inside the forum, ways to measure Vcc voltage level but not for external batteries...
As MorganS has said, use a voltage divider to limit the upper voltage to 5v. Remember that a 12v battery can go to above 14v when charging unless your charger limits it to less.
Calculate your divider on the upper voltage your battery will reach.
For your divider use something like 10K and 20K, this will give you 1/3 of the voltage or 4V.
5.000V / 1023 = 0.00488V. Which is 4.88mV x 820 (the analogue reading)=4.00V.
So 4v input = 12v battery output.
Here's a bit of my code: but I start with 2/3 not 1/3 as I only have to deal with 6V
void battCheck()
unit=0.00488; //4.88mV per analoge step
val=analogRead(A1); //Analogue value
val=val/2; //div by 2 = 1/3
bv=(unit*val)*3; // x 3 = 100%
lcd.clear();
lcd.setCursor(1,0);
lcd.print("Battery Status");
val=bv;
if(val>4.80)
lcd.setCursor(1,1);
lcd.print(val);
lcd.print(" V+ -Full");
delay(2000);
So I use 20K to Pos and 10K to GND, you need it the other way around...
