i need to have all 5 numbers to display. however according to this code I only received the first number
from the left. how do I receive all the numbers? help is needed much appreciated!!
PARTIAL CODE:
int AP_alt_set[5];
int number=0;
if (Serial.available())
CodeIn = getChar();
if (CodeIn == '=')
EQUALS(); // The first identifier is "="
char getChar()// Get a character from the serial buffer
while(Serial.available() == 0); // wait for data
return((char)Serial.read());
void EQUALS()
CodeIn = getChar(); // Get another character
switch(CodeIn)
case 'b':
Count = 0;
Digit = "";
Digit += getChar(); // Makes the string Digit what ever getChar() is holding
number= Digit.toInt();
the 'number' I received was only x. from a value of x0000
anyone help thanks!
Here is your r code modified so it will compile.
I have added some comments so you need to comment them out so it will compile for you also.
( Save me so time and let's you code ).
Essentially if you put initial if (Serial.available()) inside loo() you should also code when there is no data in the serial buffer, at lest for your info.
In general checking the serial buffer using "if" is useful when you do not want the loop() to stop and wait for the data to be in the serial buffer.But than you should have code when the "if" is false.
When your app can wait for data to be in the serial buffer "while" construct will also work.
Good luck
char CodeIn;
int Count = 0;
int Digit;
int number;
// PARTIAL CODE:
int AP_alt_set[5];
int number = 0;
//process this when Serial.available() detects data in serial buffer
//getCahr waits for data , why?
CodeIn = getChar();
nalyze data returned
if (CodeIn == '=')
continues loop when no data is in buffer OR after one byte is processed
/* waits for data in serial buffer and when data is detected reads single byte from serial buffer
while (Serial.available() == 0); // wait for data
return ((char)Serial.read());
void EQUALS()
switch (CodeIn)
case 'b':
Count = 0;
// Digit = "";
// number = Digit.toInt();
Moderator edit: This is getting tedious Vaclav. Get a grip. Code tags corrected.
A very simple example of capturing a string of numeric characters sent from the serial monitor and converting them into an integer for use.
//zoomkat 7-30-10 serial servo test
//type servo position 0 to 180 in serial monitor
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9);
Serial.println("servo-test"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the String readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured String
int n = readString.toInt(); //convert readString into a number
Serial.println(n); //so you can see the integer
myservo.write(n);
readString="";
