HELP How do you turn off the LEDs on the sound sensor? Thanks
HELP How do you turn off the LEDs on the sound sensor? Thanks.
Which Arduino ?
Which sound sensor ?
What code are you currently using ?
Use a hammer?
Ask Your mum.
What did YOU try ?
Post your effort here. (use code tags)
Too general.
A (sharp) screwdriver or craft knife would be more specific. :grin:
OP: Please remove the offensive "HELP" from your subject line in the first post.
If it's the Sparkfun Sound Detector there's a little blob of solder marked SJ6... use a sucker or wick to remove it. It's covered in the docs here...
Hope this helps... just happen to be working with one right now.
Generally (but not always) LEDs on such boards are fed with a register. If so, it's usually safe to simply short the LED with a little soldered wire.
Or you can get a little pot of black humbrol modellers enamel paint and cover it.
Resistor :grin:
