HELP HOW TO DEFAULT LIGHT OFF THIS CODE
HELP i upload this code on my arduino nano
and then all LEDS are turn on on default
i want to make all LED off in default how to make that happen?
here is the code
String voice;
int RED = 2;
int GREEN = 3;
int BLUE = 4;
void RedOn(){
digitalWrite (RED, HIGH);
void RedOff(){
digitalWrite (RED, LOW);
void GreenOn(){
digitalWrite (GREEN, HIGH);
void GreenOff(){
digitalWrite (GREEN, LOW);
void BlueOn(){
digitalWrite (BLUE, HIGH);
void BlueOff(){
digitalWrite (BLUE, LOW);
void allon() {
void alloff() {
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(BLUE, OUTPUT);
while(Serial.available()) {
delay(10);
char c=Serial.read();
if(c =='#')
{break; }
voice += c;
if (voice.length() > 0) {
Serial.println(voice);
if (voice == "on" || voice == "all")
allon() ;
else if (voice == "off" || voice=="all off")
alloff() ;
else if(voice =="red" || voice =="red on"){
RedOn();
else if(voice =="red off"){
RedOff();
else if(voice =="green" || voice =="green on"){
GreenOn();
else if( voice =="green off" ){
GreenOff();
else if(voice =="blue" || voice =="blue on"){
BlueOn();
else if(voice =="blue off"){
BlueOff();
voice="";
Hello, please, thanks?
Anyway, welcome, did you try calling alloff() at the end of setup() ?
You need to rethink a bit the way you listen to the Serial port. Don't use delay().
See Serial Input Basics
Please correct your post above and add code tags around your code:
[code]`` [color=blue]// your code is here[/color] ``[/code].
It should look like this:// your code is here
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
