!HELP! How to save incoming char as integer ?
Hello
I have Nextion touch screen. In my project, i have 12 button to touch on screen, 10 numbers, one dot(.) and one OK button. Like in the picture:
Screenshot by Lightshot
For every pressing to the buttons, i am getting a char from serial and I change this char to integer value with this code below:
int number = msg5 - '0';            // Change char to int value
For the numbers, i am getting numbers(for 1<<1,2<<2....9<<9,0<<0), for the "dot(.)" i am having 50 and for the "OK" button 51.
I want to make the numbers entered equal the any integer value like example below:
int x = ( Number entered from touch screen). For 1 digit, it is ok but for multi-digit, not. I want to enter 256, 256.7 or 1889 etc... and after pressing "OK" want to this number equal to my integer value in arduino.. Below code, i can store the numbers entered in Array, but the rest is the problem.
/* Adress Information
 * Motor1 (0,1) << X (1,1) << X^2 (1,2) << X^3 (1,3) << X^4 (1,4) << X^5 (1,5)
 * Motor2 (0,2) << X (2,1) << X^2 (2,2) << X^3 (2,3) << X^4 (2,4) << X^5 (2,5)
 * Motor3 (0,3) << X (3,1) << X^2 (3,2) << X^3 (3,3) << X^4 (3,4) << X^5 (3,5)
 * Motor4 (0,4) << X (4,1) << X^2 (4,2) << X^3 (4,3) << X^4 (4,4) << X^5 (4,5)
 * Motor5 (0,5) << X (5,1) << X^2 (5,2) << X^3 (5,3) << X^4 (5,4) << X^5 (5,5)
#include <SoftwareSerial.h>
#include <Nextion.h>
SoftwareSerial nextion(2, 3);           // Nextion Tx to 3, Rx to 2
Nextion myNextion(nextion, 9600);       // Create a Nextion object named myNextion using the nextion serial port @ 9600bps
int x = 5;                              // Number that powered
int stp1,stp2,stp3,stp4,stp5;           // Steps Results
int i = 0;
String message;                         //the last message
char msg3, msg5;                        //the values parsed from a message
int messages[10];
int buffers[10];
int rnumb;
  Serial.begin(9600);                   // Start serial communication
  myNextion.init();                     // Initialize nextion
 setMsgChar();       // Call the Function
void setMsgChar()
 message = myNextion.listen();          // Listen serial communication
  if(message !=""){                     // If message is received
    msg5 = message[5];                  // Get only the 5. char
    messages[i] = number; i++;          // Save number into array
    if(msg5 == 'a')                     // For 0 ( Zero )
      number = 0;
    Serial.println(number);             // Print the number incoming
    if(msg5 == 'c')                     // If OK is pressed. ( Not neccesary to change to Integer value )
     Serial.println("Number Entered");
Any suggestion, idea or comment ???
Thank you
Best Regards.
256.7 is NOT an integer value.
If you collect the characters in an array, and keep the array NULL terminated, you can use atoi() or atof() to convert the string to an int or a float.
PaulS:
Thanks for the advice, but the user decides that the number of digits, size of the Array.
How can i do it ? Is it possible ?
firatdk33:
If you think about the problem for a moment, there's a limit to the number of digits you need to store.
Why not use that limit to allow you to size your buffer?
