HELP!How to set Software Seial 7 bits data, Even Parity, 1 stop bit?
How can I set the SoftwareSerial to communicate with 9600baud, 7 bits data, Even Parity, 1 stop bit, no flow control device?
I am using Arduino-0023 and SoftwareSerial library. If NewSoftSerial can do this, I will update to Arduino 1.0.
Can anybody help me? Thanks.
7-bit Even Parity is just like 8-bit, No Parity except the high bit is determined from the other 7 on send and receive. You could re-write any of the software serial libraries or you could do it in software:
For each byte to be sent:
Count the 1 bits in the bottom 7 bits of the byte.
if the count is odd, set the top bit to 1, else set it to 0
send the byte.
You can similarly check the parity on received bytes or just mask the parity bit off: (byte & 0x7F)
Hi, johnwasser, thanks very much.
What I expect to receive is "30 31 31 38 34 37" and what I actually read by arduino is "30 B0 B0 B8 B0 B6"
expect actually read expect read
30: 00110000 >>>>>> 30: 00110000 ----- 30: 00110000
31: 00110001 >>>>>> B0: 10110000 ----- B1: 10110001
38: 00111000 >>>>>> B8: 10111000 ----- B8: 10111000
34: 00110100 >>>>>> B0: 10110000 ----- B4: 10110100
37: 00110111 >>>>>> B6: 10110110 ----- B7: 10110111
what do you think is the problem that make the bits wrong?
I'm going to go out on a limb and guess that it is your code that makes the bits wrong. Without seeing your code, though, we'll never know.
