Help! How to use 2 Nextion touch displays with 1 Mega
Hi guys,
I got one Nextion screen working on pins 10 and 11 with Softwareserial. I am now taking my project into a next level and I need 2 touch screens connected to the same Mega.
I tried renaming a second nextion as b but apparently I cannot use the same library for the 2 displays?
#include <Nextion.h>
#include <SoftwareSerial.h>
SoftwareSerial nextion(10, 11);// Nextion TX to pin 10 and RX to pin 11 of Arduino
Nextion myNextion(nextion, 9600);
SoftwareSerial nextion_b(12, 13);// Nextion TX to pin 12 and RX to pin 13 of Arduino
Nextion myNextion_b(nextion_b, 9600);
char rx_message_A[25];
char rx_message_B[25];
  nextion.begin(9600);
  nextion_b.begin(9600);
  myNextion.init();
  myNextion_b.init();
myNextion.listen().toCharArray(rx_message_A, 25);
myNextion_b.listen().toCharArray(rx_message_B, 25);
Serial.print(rx_message_A);
Serial.print(rx_message_B);
I already tried ITEAD support but no luck, maybe someone here could help me?
I am using this library for Nextion displays which works fine with 1 screen: https://github.com/bborncr/nextion
Thanks in advance.
Filipe
The code you posted does something. Re-read your post and see if you can figure out what it does.
You expect the code to do something. Re-read your post and see if you can figure out what you expect.
I wasn’t able to.
Why do you want to use SoftwareSerial when you have 4 HardwareSerials?
@PaulS: I want to be able to use 2 touch screens using either SoftwareSerial or Hardware Serial with an arduino Mega. Right now I have 1 touchscreen working fine on pins 10 and 11 SoftwareSerial nextion(10, 11); the other I cannot make it work either Software Serial or Hardware serial.
@Whandall: I know but I connot make it to work with hardware serial, how can I do this function with hardware serial: myNext.listen().toCharArray(rx_message_B, 25); ?
I guess like this
Nextion displayLeft(Serial1, 115200);
Nextion displayRight(Serial2, 115200);
I'm not shure how you make the Nextion communicate with 115200 or better.
PaulS: The code you posted does something. Re-read your post and see if you can figure out what it does.
I wasn't able to.
1
The code I posted is supposed to print on the serial monitor the values stored in rx_message A and B but it only works for rx_message A, I get the messages but nothing happens to rx_message B
Whandall:
I guess like this
It worked!!
Thanks, your my savier :slight_smile:
I don't even have a Nextion 8)
There was no hint in the documentation? They didn't suggest using HardwareSerial?
follow
Hello, been following this thread with interest. i am using a mega with 2 nextion displays using serial port 1 & 2. On one of the displays i am using the Nextion Library and the other just using direct serial transfer to the display using Serial2.print.
Is there a way of using the Nextion Library for both displays as it would be useful to be able to return data from both displays.
Regards.
