help - How to use an external font
Hello all.
i'm sure there is a simple answer to this, i've connected a Displaytech 240x128RGB lcd to my Duemilanove 328, as you can see the code below is messy due to the font data being dumped in the middle of it, at the moment the code just send the whole font to the lcd, my question is how to call up font data from an external file that i have created called font.h, secontly how to i call up individual character from the font table?
Thanks
byte font[762] ={
  0x00,0x00,0x00,0x00,0x00,0x00,
  0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  0x07,0x07,0x07,0x00,0x00,0x00,
  0x00,0x00,0x00,0x07,0x07,0x07,
  0xE0,0xE0,0xE0,0x00,0x00,0x00,
  0x00,0x00,0x00,0xE0,0xE0,0xE0,
  0xFF,0xFF,0xFF,0x00,0x00,0x00,
  0x00,0x00,0x00,0xFF,0xFF,0xFF,
  0x07,0x07,0x07,0x07,0x07,0x07,
  0xE0,0xE0,0xE0,0xE0,0xE0,0xE0,
  0xE0,0xE0,0xE0,0x07,0x07,0x07,
  0x07,0x07,0x07,0xE0,0xE0,0xE0,
  0xFF,0xFF,0xFF,0xE0,0xE0,0xE0,
  0xE0,0xE0,0xE0,0xFF,0xFF,0xFF,
  0x07,0x07,0x07,0xFF,0xFF,0xFF,
  0xFF,0xFF,0xFF,0x07,0x07,0x07,
  0x55,0xAA,0x55,0xAA,0x55,0xAA,
  0xAA,0x55,0xAA,0x55,0xAA,0x55,
  0x01,0x01,0x01,0x01,0x01,0x01,
  0x80,0x80,0x80,0x80,0x80,0x80,
  0xFF,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0xFF,
  0xFF,0x01,0x01,0x01,0x01,0x01,
  0x01,0x01,0x01,0x01,0x01,0xFF,
  0xFF,0x80,0x80,0x80,0x80,0x80,
  0x80,0x80,0x80,0x80,0x80,0xFF,
  0x00,0x00,0x00,0x00,0xF0,0xF0,
  0x00,0x00,0x00,0x00,0x0F,0x0F,
  0x00,0x00,0x4F,0x00,0x00,0x00,
  0x00,0x07,0x00,0x07,0x00,0x00,
  0x14,0x7F,0x14,0x7F,0x14,0x00,
  0x24,0x2A,0x7F,0x2A,0x12,0x00,
  0x23,0x13,0x08,0x64,0x62,0x00,
  0x36,0x49,0x55,0x22,0x50,0x00,
  0x00,0x05,0x03,0x00,0x00,0x00,
  0x1C,0x22,0x41,0x00,0x00,0x00,
  0x00,0x00,0x41,0x22,0x1C,0x00,
  0x14,0x08,0x3E,0x08,0x14,0x00,
  0x08,0x08,0x3E,0x08,0x08,0x00,
  0x00,0x50,0x30,0x00,0x00,0x00,
  0x08,0x08,0x08,0x08,0x08,0x00,
  0x00,0x60,0x60,0x00,0x00,0x00,
  0x20,0x10,0x08,0x04,0x02,0x00,
  0x3E,0x51,0x49,0x45,0x3E,0x00,
  0x00,0x42,0x7F,0x40,0x00,0x00,
  0x42,0x61,0x51,0x49,0x46,0x00,
  0x21,0x41,0x45,0x4B,0x31,0x00,
  0x18,0x14,0x12,0x7F,0x10,0x00,
  0x27,0x45,0x45,0x45,0x39,0x00,
  0x3C,0x4A,0x49,0x49,0x30,0x00,
  0x01,0x71,0x09,0x05,0x03,0x00,
  0x36,0x49,0x49,0x49,0x36,0x00,
  0x06,0x49,0x49,0x49,0x3E,0x00,
  0x00,0x36,0x36,0x00,0x00,0x00,
  0x00,0x56,0x36,0x00,0x00,0x00,
  0x08,0x14,0x22,0x41,0x00,0x00,
  0x14,0x14,0x14,0x14,0x14,0x00,
  0x00,0x41,0x22,0x14,0x08,0x00,
  0x02,0x01,0x51,0x09,0x06,0x00,
  0x32,0x49,0x79,0x41,0x3E,0x00,
  0x7E,0x11,0x11,0x11,0x7E,0x00,
  0x7F,0x49,0x49,0x49,0x36,0x00,
  0x3E,0x41,0x41,0x41,0x22,0x00,
  0x7F,0x41,0x41,0x22,0x1C,0x00,
  0x7F,0x49,0x49,0x49,0x41,0x00,
  0x7F,0x09,0x09,0x09,0x01,0x00,
  0x3E,0x41,0x49,0x49,0x7A,0x00,
  0x7F,0x08,0x08,0x08,0x7F,0x00,
  0x00,0x41,0x7F,0x41,0x00,0x00,
  0x20,0x40,0x41,0x3F,0x01,0x00,
  0x7F,0x08,0x14,0x22,0x41,0x00,
  0x7F,0x40,0x40,0x40,0x40,0x00,
  0x7F,0x02,0x0C,0x02,0x7F,0x00,
  0x7F,0x04,0x08,0x10,0x7F,0x00,
  0x3E,0x41,0x41,0x41,0x3E,0x00,
  0x7F,0x09,0x09,0x09,0x06,0x00,
  0x3E,0x41,0x51,0x21,0x5E,0x00,
  0x7F,0x09,0x19,0x29,0x46,0x00,
  0x46,0x49,0x49,0x49,0x31,0x00,
  0x01,0x01,0x7F,0x01,0x01,0x00,
  0x3F,0x40,0x40,0x40,0x3F,0x00,
  0x1F,0x20,0x40,0x20,0x1F,0x00,
  0x3F,0x40,0x38,0x40,0x3F,0x00,
  0x63,0x14,0x08,0x14,0x63,0x00,
  0x07,0x08,0x70,0x08,0x07,0x00,
  0x61,0x51,0x49,0x45,0x43,0x00,
  0x7F,0x41,0x41,0x00,0x00,0x00,
  0x02,0x04,0x08,0x10,0x20,0x00,
  0x00,0x00,0x41,0x41,0x7F,0x00,
  0x04,0x02,0x01,0x02,0x04,0x00,
  0x40,0x40,0x40,0x40,0x40,0x00,
  0x00,0x01,0x02,0x04,0x00,0x00,
  0x20,0x54,0x54,0x54,0x78,0x00,
  0x7F,0x48,0x44,0x44,0x38,0x00,
  0x38,0x44,0x44,0x44,0x20,0x00,
  0x38,0x44,0x44,0x48,0x7F,0x00,
  0x38,0x54,0x54,0x54,0x18,0x00,
  0x08,0x7E,0x09,0x01,0x02,0x00,
  0x0C,0x52,0x52,0x52,0x3E,0x00,
  0x7F,0x08,0x04,0x04,0x78,0x00,
  0x00,0x44,0x7D,0x40,0x00,0x00,
  0x00,0x20,0x40,0x44,0x3D,0x00,
  0x7F,0x10,0x28,0x44,0x00,0x00,
  0x00,0x41,0x7F,0x40,0x00,0x00,
  0x7C,0x04,0x18,0x04,0x78,0x00,
  0x7C,0x08,0x04,0x04,0x78,0x00,
  0x38,0x44,0x44,0x44,0x38,0x00,
  0x7C,0x14,0x14,0x14,0x08,0x00,
  0x08,0x14,0x14,0x18,0x7C,0x00,
  0x7C,0x08,0x04,0x04,0x08,0x00,
  0x48,0x54,0x54,0x54,0x20,0x00,
  0x04,0x3F,0x44,0x40,0x20,0x00,
  0x3C,0x40,0x40,0x20,0x7C,0x00,
  0x1C,0x20,0x40,0x20,0x1C,0x00,
  0x3C,0x40,0x30,0x40,0x3C,0x00,
  0x44,0x28,0x10,0x28,0x44,0x00,
  0x0C,0x50,0x50,0x50,0x3C,0x00,
  0x44,0x64,0x54,0x4C,0x44,0x00,
  0x08,0x36,0x41,0x00,0x00,0x00,
  0x00,0x00,0x7F,0x00,0x00,0x00,
  0x00,0x00,0x41,0x36,0x08,0x00,
  0x00,0x08,0x04,0x08,0x04,0x00};
  DDRB = 63; // PortB Bits 0,1,5 - Digital Pins 8,9,13 are Outputs
  DDRD = 255; // PortD - Digital Pins 0 - 7 are Outputs
  Init_LCD();
  Clr_LCD();
  for (long i=0; i<762; i++) Data_W(font[i]);
void Init_LCD()
  Com_W(226);  // #11100010B  SYSTEM RESET
  delay(100);
  Com_W(0);    // #00000000B  SET COLUMN LSB
  Com_W(0);    // #00000000B  SET COLUMN MSB
  Com_W(0);    // #01000000B  SET START LINE
  Com_W(36);   // #00100100B  SET MUX & TEMP. COMPENSATION
  Com_W(45);   // #00101101B  SET POWER CONTROL
  Com_W(129);  // #10000001B  SET GAIN
  Com_W(128);  // #10000000B  SET POTENTIOMETER
  Com_W(137);  // #10001001B  RAM CONTROL
  Com_W(164);  // #10100100B  ALL PIX OFF
  Com_W(166);  // #10100110B  INVERSE
  Com_W(175);  // #10101111B  SLEEP MODE OFF
  Com_W(200);  // #11001000B  MY=1 MX=1 MSF=0
  Com_W(234);  // #11101010B  BIAS=12
void Com_W(int dat)
  PORTB = 0;
  PORTD = dat;
  PORTB = 1;
  PORTB = 0;
void Data_W(int dat)
  PORTB = 2;
  PORTD = dat;
  PORTB = 3;
  PORTB = 2;
void Clr_LCD()
  for (long i=0; i<30720; i++) Data_W(0);
