Every time I try to click the check, or upload buttons, it almost instantly says: exit status 1
Error compiling for board Arduino/Genuino Uno.
I've tried everything that I can think of but it always comes up with the same error message. Why it says int out4=9; is because the pin 11 is broken on my arduino. I can't put any wires into pin 11. Please Help! The code that I'm using is:
int A4pin=A5;
int A2pin=A3;
int A1pin=A1;
int B4pin=2;
int B2pin=4;
int B1pin=6;
int out8=10;
int out4=9;
int out2=12;
int out1=13;
void Setup() {
pinMode(A4pin,INPUT);
pinMode(A2pin,INPUT);
pinMode(A1pin,INPUT);
pinMode(B4pin,INPUT);
pinMode(B2pin,INPUT);
pinMode(B1pin,INPUT);
pinMode(out8, OUTPUT);
pinMode(out4, OUTPUT);
pinMode(out2, OUTPUT);
pinMode(out1, OUTPUT);
void Loop() {
int A4val=0;
int A2val=0;
int A1val=0;
int B4val=0;
int B2val=0;
int B1val=0;
int Aval;
int Bval;
int outval;
A4val = digitalRead(A4pin);
A2val = digitalRead(A2pin);
A1val = digitalRead(A1pin);
B4val = digitalRead(B4pin);
B2val = digitalRead(B2pin);
B1val = digitalRead(B1pin);
int A4valcal = A4val;
int A2valcal = A2val;
int A1valcal = A1val;
int B4valcal = B4val;
int B2valcal = B2val;
int B1valcal = B1val;
if (A4val==0){
A4valcal = 1;
if (A4val==1){
A4valcal = 0;
if (A2val==0){
A2valcal = 1;
if (A2val==1){
A2valcal = 0;
if (A1val==0){
A1valcal = 1;
if (A1val==1){
A1valcal = 0;
if (B4val==0){
B4valcal = 1;
if (B4val==1){
B4valcal = 0;
if (B2val==0){
B2valcal = 1;
if (B2val==1){
B2valcal = 0;
if (B1val==0){
B1valcal = 1;
A4val = A4valcal;
A2val = A2valcal;
A1val = A1valcal;
B4val = B4valcal;
B2val = B2valcal;
B1val = B1valcal;
Serial.print("A = ");
Serial.print(A4val);
Serial.print(A2val);
Serial.println(A1val);
Serial.print("B = ");
Serial.print(B4val);
Serial.print(B2val);
Serial.println(B1val);
Aval=(A4val4)+(A2val2)+(A1val1);
Bval=(B4val4)+(B2val2)+(B1val1);
outval=Aval+Bval;
Serial.println("total = outval");
Serial.println(outval);
Serial.println("");
digitalWrite(out8,LOW);
digitalWrite(out4,LOW);
digitalWrite(out2,LOW);
digitalWrite(out1,LOW);
if (outval>=8) {
digitalWrite(out8,HIGH);
outval=outval-8;
if (outval>=4) {
digitalWrite(out4,HIGH);
outval=outval-4;
if (outval>=2) {
digitalWrite(out2,HIGH);
outval=outval-2;
if (outval>=1) {
digitalWrite(out1,HIGH);
outval=outval-1;
