My program consist on an interface to automate a home, everything seems to be ok, but when i choose the option of turning off the lights in the programation it didn't work, i need some help and i would like someone to recomend me some things to improve this work, thanks a lot.
This is the program:
#include <Keypad.h>
#include <LiquidCrystal.h>
//LED
int led_rojo = 1;
int led_verde = 0;
int led_azul =2;
int led_ama =3;
//Teclado
const byte TAM_COLS = 4;
const byte TAM_FILS = 4;
byte COLUMNAS[TAM_COLS] = {17,16,15,14 };
byte FILAS[TAM_FILS] = {21, 20, 19, 18};
char keys[TAM_FILS][TAM_COLS] = {
{ '1','2','3','A' } ,
{ '4','5','6','B' } ,
{ '7','8','9','C' } ,
{ '*','0','#','D' } };
char idioma;
Keypad teclado = Keypad (makeKeymap(keys), FILAS, COLUMNAS, TAM_FILS, TAM_COLS);
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); //Pins LCD
lcd.begin(16,2);
pinMode(led_rojo, OUTPUT);
pinMode(led_verde, OUTPUT);
pinMode(led_azul, OUTPUT);
pinMode(led_ama, OUTPUT);
menu_idioma();
char tecla = teclado.getKey();
Serial.println("Tecla Idioma");
switch (tecla)
case '1': idioma = 'N';
menu_ingles();
menu(); tecla = ' ';
case '2': idioma = 'S';
menu_espanol();
menu();
tecla = ' ';
void menu()
char tecla1;
do{
tecla1 = teclado.getKey();
Serial.println("Tecla Menu 2");
switch (tecla1)
case '1':
submenu();
encender_luces();
case '2':
submenu();
apagar_luces();
case '3':
mostrar_temperatura();
while(tecla1 != '4' );
void menu_idioma(){
lcd.clear();
lcd.print("1.English");
lcd.setCursor(0, 1);
lcd.print("2.Espanol");
void menu_espanol()
lcd.setCursor(0, 0);
lcd.print("** BIENVENIDO **");
lcd.print("****************");
delay(1500);
lcd.clear();
lcd.print("1.Encender luces");
lcd.print("2.Apagar luces");
delay(1500);
lcd.clear();
lcd.print("3.Temperatura");
lcd.print("4.Salir");
void menu_ingles(){
lcd.print("*** WELCOME ***");
delay(1500);
lcd.clear();
lcd.print("1.LED ON");
lcd.print("2.LED OFF");
delay(1500);
lcd.clear();
lcd.print("3.Temperature");
lcd.print("4.Exit");
void submenu(){
switch (idioma){
case 'N':
submenu_ingles();
case 'S':
submenu_espanol();
void submenu_ingles()
lcd.print("1.Red 2.Green");
lcd.print("3.All 4.Exit");
void submenu_espanol()
lcd.print("1.Rojo 2.Verde");
lcd.print("3.Todo 4.Salir");
void encender_luces()
char tecla2;
do{
tecla2 = teclado.getKey();
Serial.println("Tecla Submenu Encender");
switch (tecla2)
case '1':
encender_rojo();
case '2':
encender_verde();
case '3':
encender_rojo();
encender_verde();
case '4':
switch (idioma)
case 'N':
menu_ingles();
case 'S':
menu_espanol();
while(tecla2 != '4' );
void apagar_luces()
char tecla2;
do{
Serial.println("Tecla Submenu Apagar");
switch (tecla2)
case '1':
apagar_rojo();
case '2':
apagar_verde();
case '3':
apagar_rojo();
apagar_verde();
case '4':
switch (idioma)
case 'N':
menu_ingles();
case 'S':
menu_espanol();
void encender_rojo()
digitalWrite(led_rojo,HIGH);
void encender_verde()
digitalWrite(led_verde,HIGH);
void apagar_rojo()
digitalWrite(led_rojo,LOW);
void apagar_verde()
digitalWrite(led_verde,LOW);
void mostrar_temperatura()
char tecla2;
do{
obtener_temperatura();
if (tecla2 == '4')
switch (idioma)
case 'N':
menu_ingles();
case 'S':
menu_espanol();
void obtener_temperatura()
lcd.print(" C");
switch (idioma)
case 'N':
case 'S':
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
