Help! I have some questions with a circuit I am trying to build.
So I am wanting to control an LED's brightness (or eventually a 7 segment display's brightness but simple first) with an IR remote and receiver. Now I know how to setup the whole IR part of the circuit as far as the IR receiver and the codes that it receives from the remote but what code do i use to control the LED's brightness with the IR remote? Do I need any other hardware aside from the LED, Uno, and IR receiver and transmitter? Thanks!
Have you tried a project to control LED brightness with PWM? Try doing a search on "arduino uno led brightness pwm" to get started.
You can have each button result in a different LED brightness ‘OR’ use the UP arrow and DOWN arrow to raise and lower the LED intensity.
If you use a 7-segment display driven by a MAX7219, its brightness is programmable in 16 steps.
I am pretty new to arduino. Could I possibly get an example of what code I would need to add to this to say, control an LED that plugs into pin 13. Here is the code for my IR remote.
Power FFA25D
Mode FF629D
Mute FFE21D
Pause FF22DD
Reverse FF02FD
Fast Forward FFC23D
EQ FFE01F
Minus FFA857
Plus FF906F
Zero FF6879
Rearrange FF9867
USB/Scan FFB04F
One FF30CF
Two FF18E7
Three FF7A85
Four FF10EF
Five FF38C7
Six FF5AAF
Seven FF42BD
Eight FF4AB5
Nine FF52AD
So how would I add something so when I press the plus and minus key, it goes up or down by say 5% or 10%? This is the code I have now, this is just to get the IR signal to the actual Uno but I don’t know how to add the other function. Wouldn’t it but something like
If(FF906F) and then something else?
Thanks!
Google ‘Arduino switch’
https://www.arduino.cc/reference/en/language/structure/control-structure/switchcase/
Can you see how switch/case could be used to respond to a remote button push ?
Have you looked at the examples that come with the IR library ?
An example:
#include "IRremote.h"
//LarryD
//Sketch to demonstrate using an IR hand remote to control Arduino outputs.
//The remote used here uses the NEC protocol.
//This remote sends the button code (example 0xFF629D) then a repeat code 0xFFFFFFFF
//The repeat code is re-sent as long as an IR remote button is pressed.
//The IR receiver used is the TSOP4838
/*  17 IR button remote layout   http://i.imgur.com/X1KIdqI.png
< OK  >
   v
1  2  3
4  5  6
7  8  9
*  0  #
const byte RECV_PIN = 7;   //IR receive pin
IRrecv irrecv(RECV_PIN);   //create instance of 'IRrecv'
decode_results results;    //create instance of 'decode_results'
unsigned long   TimerUp;   //UP arrow on the remote
boolean         TimerUpFlag = false;
unsigned long   TimerDown; //DOWN arrow on the remote
boolean         TimerDownFlag    = false;
unsigned long   TimerIntensity;
unsigned long   TimerIncDec;
boolean         intesityUpFlag   = false;
boolean         intesityDownFlag = false;
int             brightness;
unsigned long   dummy;
unsigned long * TimerPtr = &dummy; //pointer to the current timer
const byte upLED        = 13;  //turns on as long as the UP button is pressed
const byte downLED      = 12;  //turns on as long as the DOWN button is pressed
const byte leftLED      = 11;  //toggles on/off
const byte rightLED     = 10;  //toggles on/off
const byte intensityLED =  9;  //a LED which can have its intensity adjusted
//                           s e t u p ( )
  irrecv.enableIRIn(); //start receive
  pinMode(upLED,   OUTPUT);
  pinMode(downLED, OUTPUT);
  pinMode(leftLED, OUTPUT);
  pinMode(rightLED, OUTPUT);
  pinMode(intensityLED, OUTPUT); //this is a PWM output pin
} //                    E N D  O F  s e t u p ( )
//                            l o o p ( )
  if (irrecv.decode(&results)) //is there IR remote button code
    //Serial.println(results.value);
    processButton(); //process button press
    irrecv.resume(); //restart for next button press
  //**********************                                //Turn off upLED
  //if timing is enabled, is it time to stop
  if (TimerUpFlag && millis() - TimerUp >= 250ul)
    TimerUpFlag = false; //disable timing
    TimerPtr = &dummy;   //pointer to dummy timer
    digitalWrite(upLED, LOW);
  //**********************                                //Turn off downLED
  if (TimerDownFlag && millis() - TimerDown >= 250ul)
    TimerDownFlag = false; //disable timing
    digitalWrite(downLED, LOW);
  //**********************                                //LED intensity
  //are we still within the adjustment time
  if (millis() - TimerIntensity <= 300ul)
    //is it time to increase/decrease the intensity
    if (millis() - TimerIncDec >= 200ul)
      TimerIncDec = millis();
      if (intesityUpFlag == true) //Increase
        brightness += 5;
        if (brightness > 255)
          brightness = 255;
      else if (intesityDownFlag == true) //Decrease
        brightness -= 5;
        if (brightness < 0)
          brightness = 0;
      analogWrite(intensityLED, brightness);
      //Serial.println(brightness); //debug
  //stop increasing/decreasing intensity
  //Other non blocking code goes here
} //                   E N D  O F  l o o p ( )
//                       F U N C T I O N S
//                   p r o c e s s B u t t o n ( )
//process IR remote button presses
void processButton()
  switch (results.value)
    case 0xFF629D:                                           //UP Arrow
        Serial.println("UP");
        TimerPtr = &TimerUp;  //point to this timer
        TimerUpFlag = true;   //enable timing
        digitalWrite(upLED, HIGH);
        TimerUp = millis();
    case 0xFFA857:                                           //DOWN Arrow
        Serial.println("DOWN");
        TimerPtr = &TimerDown;  //point to this timer
        TimerDownFlag = true;   //enable timing
        digitalWrite(downLED, HIGH);
        TimerDown = millis();
    case 0xFF22DD:                                           //LEFT Arrow
        Serial.println("LEFT");
        digitalWrite(leftLED, !digitalRead(leftLED));   //Toggle LED
    case 0xFFC23D:                                           //RIGHT Arrow
        Serial.println("RIGHT");
        digitalWrite(rightLED, !digitalRead(rightLED)); //Toggle LED
    case 0xFF42BD:                                           // * button
        Serial.println("*");
        TimerPtr = &TimerIntensity;  //point to this timer
        intesityUpFlag = true;       //enable intensity up adjustment
        TimerIntensity = millis();
   case 0xFF52AD:                                           // # button
        Serial.println("#");
        intesityDownFlag = true;     //enable intensity down adjustment
    case 0xFF02FD:
      Serial.println("OK");
    case 0xFF6897:
      Serial.println("1");
    case 0xFF9867:
      Serial.println("2");
    case 0xFFB04F:
      Serial.println("3");
    case 0xFF30CF:
      Serial.println("4");
    case 0xFF18E7:
      Serial.println("5");
    case 0xFF7A85:
      Serial.println("6");
    case 0xFF10EF:
      Serial.println("7");
    case 0xFF38C7:
      Serial.println("8");
    case 0xFF5AA5:
      Serial.println("9");
    case 0xFF4AB5:
      Serial.println("0");
    case 0xFFFFFFFF: //Repeat code
        Serial.println("REPEAT");
        *TimerPtr = millis();       //reset the current timer
  } // END switch case
} //             E N D  o f  p r o c e s s B u t t o n ( )
//                        E N D  O F  C O D E
