hi ,
i tell the situation
i have a iboard (328+) that i use to play bridge between wireless nrf24l01 devices and a SQL server and a UDP server.
The iboard is pretty because everything is at one.
but if i upload my sketch on the iboard the program doens't run it's halt on the sql connection.
If i place the sketch on a Mega board it runs fine.
here a show you the sketch , i now its a little bit messy , but its my first great script
#include <digitalWriteFast.h>
#include <iBoardRF24Network.h>
#include <iBoardRF24.h>
#include <SPI.h>
#include "Ethernet.h"
#include "sha1.h"
#include "mysql.h"
#include <EthernetUdp.h>
char user[] = "root";
char password[] = "wortel";
char INSERT_SQL[50];
char REMOTEDATA[20];
char type ;
// BASE1
byte mac_addr[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFD, 0xAA };
IPAddress ip(192, 168, 111, 171);
const uint16_t this_node = 01;
IPAddress server_addr(192, 168, 111, 150);
IPAddress remote(192, 168, 111, 105);
unsigned int remoteport = 8888;
void UDPDATA(int ploegnr, int code, int teller, int tellerplus);
Connector my_conn;
EthernetUDP Udp;
iBoardRF24 radio(3,8,5,6,7,2);
//iBoardRF24 radio(30,31,32,33,34,35);
iBoardRF24Network network(radio);
const unsigned long interval = 100;
unsigned long last_sent;
unsigned long packets_sent;
struct boodschap_t
unsigned int code;
unsigned int ploeg;
struct control_t
unsigned int ploegnr;
unsigned int rondecontrol;
unsigned int opstartcontrol;
int ploegdata [5][6] =
// BASE1
// {ploeg , code , node , teller, tellerstop , tellerplus}
1,555,011,0,0,0 }
2,555,2,0,0,0 }
3,555,3,0,0,0 }
4,555,4,0,0,0 }
5,555,5,0,0,0 }
void setup(void)
Serial.begin(57600);
Serial.println("Base gestart");
SPI.begin();
Ethernet.begin(mac_addr);
Udp.begin(remoteport);
radio.begin();
network.begin(/*channel*/ 90, /*node address*/ this_node);
bool dok = radio.setDataRate(RF24_2MBPS);
if (my_conn.mysql_connect(server_addr, 3306, user, password))
Serial.print("connect ");
Serial.print("fout ");
void loop(void)
network.update();
unsigned long now = millis();
if ( now - last_sent >= interval )
last_sent = now;
for (int i = 0 ; i < 5 ; i++)
int ploeg = 0;
int code = 555;
ploeg = ploegdata[i][0];
int other_node = ploegdata[i][2];
if (ploegdata[i][3] < 5)
ploegdata[i][1]= 555;
type ='I';
ploegdata[i][5]++;
if (ploegdata[i][3] == 5)
ploegdata[i][1]= 666;
type ='C';
sprintf(INSERT_SQL, "INSERT INTO score.Ronde VALUES (NULL, %d, NULL)", ploegdata[i][0]);
my_conn.cmd_query(INSERT_SQL);
ploegdata[i][5] = 0;
ploegdata[i][4] = 0;
if (ploegdata[i][3] > 5)
ploegdata[i][1]= 111;
type ='O' ;
boodschap_t boodschap = {code ,ploeg};
RF24NetworkHeader header(other_node, type);
bool ok = network.write(header,&boodschap,sizeof(boodschap));
if (ok)
UDPDATA(ploegdata[i][0],ploegdata[i][1],ploegdata[i][5]);
ploegdata[i][3]++;
ploegdata[i][4] = 0 ;
if (ploegdata[i][4] == 0)
ploegdata[i][1] = 777;
ploegdata[i][4] = 1;
ploegdata[i][3]=0;
code = 777;
delay(100);
network.update();
while ( network.available() )
RF24NetworkHeader haader;
control_t control;
network.read(haader,&control,sizeof(control));
sprintf(INSERT_SQL, "INSERT INTO score.control VALUES (NULL, %d, %d, NULL)", control.rondecontrol,control.opstartcontrol);
void UDPDATA(int ploegnr, int code, int tellerplus)
sprintf(REMOTEDATA, "%d#%d#%d", ploegnr,code,tellerplus);
Udp.beginPacket(remote, remoteport);
Udp.write(REMOTEDATA);
Udp.endPacket();
if i comment the sprintf lines , everything works fine except the writing to the servers of course.
with the sprintf lines uncomment i have only 300bytes free
what can i do to make more running memory
Help o Help
