I'm beginner in Arduino and I need to create a kind of schedule.
the aim is to make the arduino able to know what day of the week and we also know the precise time.
I've used the example of DateTime arduino playground but could not get any results.
I had many errors declaration functions.
I need to know if the code is correct and functional? yes if someone can help me put my project in motion?
I know, but DATE and TIME is simplest way to "push" current date and time to Arduino and work with these. In combination with a time.h library Arduino can show almost current date and time after sketch is uploaded.
In moment i have a Tiny RTC I2C module but when i run the example sketch "TimeRTC" the program return the error:
TimeRTC.pde: In function 'void setup()':
TimeRTC:14: error: 'RTC' was not declared in this scope
So i can't know what is the time and date in RTC.. Can you help me with this problem?
In fact i have the lib <DS1307RTC.h> installed but the problem may be linked with the function RTC.get() in this library.
So like i said my program can’t recognize the function and report me the error.
I can’t understand this. I have doing install/uninstall the library <DS1307RTC.h> and the problem still exist.
Can you tell me if it may be the version I’m using arduino?
Do you mean that LED13 sometimes blinks and upload of sketch fails? My last piece of knowledge (or my hard "new discovery") is three exclamation marks problem. Simply remove !!! from your sketch (if they are there).
For better advises, please attach your sketch to post (if it is long) or use CODE tags ( [ # ] icon ) and publish your sketch.
Now i have a Arduino MEGA and when i doing 'compile' sketch the led 13 blinkly. What make this possible? RAM of system?
I use many array and e need replace UNO for MEGA and after some code lines the problem return. I do not know what can be.
after compiling the program says: "Binary sketch size: 18.084 bytes (of a 258.048 byte maximum)"
It's not normal..i think.
Thanks
Which part of this is the problem you're asking for help with? Are you having trouble compiling the sketch, or uploading it, or a problem with what it does when it runs?
actually I’m having the same problem with MEGA.
I have some variables declared as local and, when put as overall program, the memory occupied greatly increases.
Now, with the development of the code, the memory is increasing again, preventing me from continuing the program.
I do not know if you can be be using many arrays but I do have to use them.
I do not look anything like normal memory usage is growing very much every cycle if / for that I implement.
Oh yes, I also had the same problems with memory! But forum users advised me to use keyword PROGMEM and F macro.
It is simply:
Serial.print("Hello!");
occupies 6 bytes of Flash EPROM and also 6 bytes of RAM !!!
Serial.print(F("Hello!"));
occupies only 6 bytes of Flash EPROM and no RAM
PROGMEM is little complicated to use, so look for examples to learn.
