help!! i need to make some Calculator from adruino
i need to make + - * / in my arduino
my code can use on tinkercard can running but can't use on arduino
sorry my english bad
this my code
#include <math.h>
#include <stdio.h>
int buttonState = 0;
int lesAvPC() { //vil ha float her - This is where I want float
  while (Serial.available() == 0);
  return Serial.parseInt();
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(13, OUTPUT);
  Serial.println("=================================");
  Serial.println("Test Serial by stdio.h");
  Serial.println("Lab6");
  Serial.println("Arithmetic(+,-,*,/");
  Serial.println("=============================");
  Serial.println("Select Arithmetic Menu");
  Serial.println("1.Plus(+)");
  Serial.println("2.Minus(-)");
  Serial.println("3.Multiply(*)");
  Serial.println("4.Divide(/)");
  Serial.println("==================================");
  Serial.println("Please push the button for select menu");
  buttonState = digitalRead(2);
  if (buttonState == HIGH) {
    Serial.print("1.Input Enter First value: ");
        float num1 = lesAvPC();
        Serial.println(num1);
        Serial.println("   Operand:  +");
        Serial.print(" Input Enter Second value: ");
        float num2 = lesAvPC();
        Serial.println(num2);
        Serial.println(" ");
        Serial.print("      Answer: ");
        float fasit = num1 + num2;
        Serial.println(fasit);
        Serial.println("........................................");
  buttonState = digitalRead(3);
    Serial.print("2.Input Enter First value: ");
        Serial.println("   Operand:  -");
        float fasit = num1 - num2;
  buttonState = digitalRead(4);
    Serial.print("3.Input Enter First value: ");
        Serial.println("   Operand:  *");
        float fasit = num1 * num2;
  buttonState = digitalRead(5);
    Serial.print("4.Input Enter First value: ");
        Serial.println("   Operand:  /");
        float fasit = num1 / num2;
i must use switch case,push button,serial
please help thank you
How are your buttons wired?
Research the correct use of INPUT_PULLUP.
