Screenshots of code are worthless. I cannot put the code into an editor for examination. Read the how to use this forum-please read stickies to see how to post code and error messages. Following the guidelines will save everyone time and get you faster and better help. Also read #11 to get an idea of the information that will help us help you.
The screen shot only shows "Exit status 1" which means "There was an error." Copy and paste ALL of the text in that text box below the sketch. That will include the actual error messages.
One common beginner error is "no such file or folder" which means you didn't install one of the required libraries.
The sketch they provide doesn’t use any libraries so that’s not the problem.
My guess is that you copied the sketch incorrectly or you selected an Arduino that didn’t have an ATmega328P processor (UNO, Mini, Nano) so some hardware register names used in the sketch aren’t defined.
byte TP = 0b10101010; // Every other port receives the inverted signal
DDRC = 0b11111111; // Set all analog ports to be outputs
// Initialize Timer1
noInterrupts(); // Disable interrupts
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 200; // Set compare register (16MHz / 200 = 80kHz square wave -> 40kHz full wave)
TCCR1B |= (1 << WGM12); // CTC mode
TCCR1B |= (1 << CS10); // Set prescaler to 1 ==> no prescaling
TIMSK1 |= (1 << OCIE1A); // Enable compare timer interrupt
interrupts(); // Enable interrupts
ISR(TIMER1_COMPA_vect)
PORTC = TP; // Send the value of TP to the outputs
TP = ~TP; // Invert TP for the next run
// Nothing left to do here :)
