help i think i broke my arduino uno wifi
hi i am a massive noob when it comes to arduino but yeah
i recently bought an arduino uno wifi and was fooling ardound with it when suddenly my eye fell on this little button next to the wifi led next to the button it says esp b/l i pressed it and all the wificonnections it had dropped i cannot connect to it annymore via wifi and dont even know whats wrong.
is there annyone who knows what to do?
you made it forgot the wifi connection parameters. connect to it's AP like first time (192.168.240.1) and configure the connection.
Juraj:
i have already tried that but without any result i can't even connect to the ip.
and the Arduino-Uno-WiFi-xxxxxxx network is visible?
did you try reconnecting usb power?
Juraj:
no its not i have tried multiple devices and none of them is able to find it and yes i did i can send data over the com ports but that just gets rid of the whole wifi point... the reason i bought it was the wifi so i'd like to use the wifi
do you use the bottom plastic cover? this kind of problem is from touching sensitive soldering points on the bottom side of the board.
try the recovery procedure with firmware updater
