help I wan to make 10 pieces of led flashing alternately
the master give solution , I want to make 10 pieces of led flashing alternately , the delay between the LED can be arranged with 2 push button for delay up and down , 10 steps delay, from 10 seconds to 100 seconds :slight_smile:
give solution for arduino code
(deleted)
That's fine, you don't have to ask permission.
2 parts single malt, 0.001 parts water.
You may find some useful stuff in planning and implementing a program. It includes some LEDs flashing.
…R
check the basic programs that come with the Arduino software. this should be simple. once you have figured it out, come back and let us know how you have done
if your programming does not work, come back , read the forum rules on how to post code. then post your code and tell us what did not work.
hints
look and blink without delay and switch
]quote]
the master give solution ,, I want to make 10 pieces of led flashing alternately , the delay between the LED can be arranged with 2 push button for delay up and down , 10 steps delay, from 10 seconds to 100 seconds give solution for arduino code
NO! [/quote] whatsamatter, you think that he will not give you credit on his course ?
