Help...I want to press a button 2 start a cycle once done wait for press again
I want to do the following..
Press a button then the
YELLOW come ON for 1 second
Then another yellow comes ON for 1 second
Then the GREEN light comes ON for 5 seconds
Then the system resets and waits for the press of the button to do it all over again.
I have 3 relays wired and have the time code done.
What I need help with is where to wire in the start button and what code do I use?
I could just put a switch in the power line going to the board and each time I power it up it will do what I want.
But, I don't think that is the proper way to do what I need to do.
Thanks for any help on this.
You need to look at DigitalRead command. Always look at the Arduino EXAMPLES that come with the IDE first..
Button
Turns on and off a light emitting diode(LED) connected to digital
pin 13, when pressing a pushbutton attached to pin 7.
The circuit:
  • LED attached from pin 13 to ground
  • pushbutton attached to pin 2 from +5V
  • 10K resistor attached to pin 2 from ground
  • Note: on most Arduinos there is already an LED on the board
    attached to pin 13.
created 2005
by DojoDave http://www.0j0.org
modified 17 Jun 2009
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Button
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
else {
// turn LED off:
digitalWrite(ledPin, LOW);
