HELP: i want to send a string via a web page HTML
Hello everybody,
i want to send a string via a web page HTML. I write my code, i know its wrong but if you have any ideas would be helpful.
thank you very much!!
#include <SPI.h>
#include <Client.h>
#include <Ethernet.h>
#include <Server.h>
#include <Udp.h>
#include <String/WString.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1, 35); // ip del rango establecido en el router
char producto[24];
byte contador=0;
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
String readString = String(30);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  // listen for incoming clients
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (readString.length()<30) //leer peticion HTTP caracter por caracter
           readString += c;
        if (c=='\n') //Si la peticion HTTP ha finalizado
        }//while
          Serial.print(producto);
          readString=""; //Vaciar el string que se uso para la lectura
          //Enviar cabecera HTTP estandar
          client.println("Content-Type: text/html");
          client.println();
          //Crear pagina web HTML
          client.println("<html>");
          client.println("<head>");
          client.println("<title>Centro de control de productos</title>");
          client.println("</head>");
          client.println("<body>");
          client.println("<h1>Centro de control de productos</h1>");
          client.println("
<hr>
          client.println("<b>Nombre del Producto");
          client.println("
<form method=get enctype=text/plain> <input type=text name=nombreproducto size=25 maxlength=50>
          client.println("<hr><input type=submit name=Aceptar value=Introducir><input type=Reset name=Cancelar value=Cancelar></form>");
          client.println("</body>");
          client.println("</html>");
          client.stop();
alozamonto:
i know its wrong
What problem are you asking for help with?
i know its wrong
Why don't you fix it, then?
Or explain what the code does that you don't want, or doesn't do that you want.
String readString = "30";
would do the same thing. How is that initial value useful?
I want to keep the variable "nombreproducto" . This variable is entered through the website HTML
  client.println("
I have not yet programmed, i have only the website programmed, but I think I should set it here to copy the string
if (client) {
           readString += c;
        }//while
Sorry but i am from Spain and I do not write very well in English.
thanks
So, why don't you?
What IS in readString when the \n arrives?
Server test code that uses a form text box to make a GET request. You can view what the server is receiving by using the serial monitor.
//zoomkat 12-08-12
//get submit box code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html or use a '
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84);; //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("server text box test1"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //see what was captured
          //now output HTML data header
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>HTML form GET example</H1>");
          client.println("<FORM ACTION='/' method=get >"); //uses IP/port of web page
          client.println("Pin 5 'on' or 'off': <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'>
          client.println("<INPUT TYPE=SUBMIT NAME='submit' VALUE='Change Pin 5!'>");
          client.println("</FORM>");
          client.println("
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          if(readString.indexOf("on") >0)//checks for on
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
I have tried but i have many problems, i want to keep "nombredeproducto" to my arduino via a website HTML
          client.println("
I think this is very interesting because i want a string to send and i have not found any example.
Thank you very much
This is my code:
#include <SPI.h>
#include <Client.h>
#include <Server.h>
#include <Udp.h>
byte gateway[] = {192, 168, 2, 254 };
char producto[24];
byte contador=0;
  Ethernet.begin(mac, ip, gateway);
  server.begin();
  if (client) {
           readString += c;
           producto[contador] = c;
           contador++;
              if(Serial.available()){
                  memset(producto, 0, sizeof(producto)); // Borrado de la cadena
                  while (Serial.available()>0){ // ¿Existe comunicacion?
                  delay(5); // Permite llenar el buffer
                  producto[contador]=Serial.read(); // Lectura de teclado via serial.
                  contador++;
          client.println();
          client.println("
<hr>
          client.println("
          client.stop();
         Serial.println(producto);
Language might be one of them, because this statement makes no sense. You can't send a webpage to the Arduino. The Arduino can serve up a page. If the page contains a form, with a submit button, and an action field, that action field can cause another GET request to be made. If the form also contains text fields, the contents of those fields will be part of the GET request. You can then parse the GET request, to see if it contains anything for you to deal with, as opposed to an initial request for the page.
What ARE you getting?
Please give me the Library
<String / WString.h>
You already have that library. You should NOT be using it.
