Help Identifiying a component
Hi Guys,
I recently bought a Chinese personal space air con unit. Needless to say it wasn't very good, and it quickly broke apart. I'm trying to improve on the design a bit, but I can't identify this component (attached images)
It came from the base of the water tank, and has some seals that i've removed, so I assume it's for regulating the amount of water that is dispensed, but I have no idea what to search to find a replacement.
Any help would be greatly appreciated :smiley:
Looks like some kind of sensor. Does it mechanically actuate? It could be a bi-metal temperature sensor. Though I don't know what it would be doing on a water tank. Or why an air conditioner unit has a water tank. (Is it to capture the condensed water?)
OK i'll take a guess... I'm leaning towards ultrasonic liquid level sensor. This looks incomplete because it looks like just the transducer for one... possibly
Looks a bit like an ultrasonic misting transducer.
wolframore is close and Riva is correct.
It does not have one single name.
It can be called:
  • Piezo Ceramic Misting Element
  • Ultrasonic Humidifier Piezoelectric Transducer
  • Ultrasonic Atomizing Transducer Mist Maker Ceramic Disc
A signal of 1.5 MHz to 2 MHz is used to create the water mist. There must be not too much and not too little water above it, so I assume that there was some kind of mechanical way to do that.
Keppel I think you might be right. There is a fixed sized hole above it. Also explains what the IC connected to it was
Can you link to the of machine? Inquiring minds and all :slight_smile:
GHONLZIN Mini Air Cooler, 2019 New Mini Air Conditioner, Portable Cooler Fan Air Conditioner Cooler for Home with New Filter Paper (2 Generation-Upgrade) (2#) https://www.amazon.co.uk/dp/B07QMPZYMK/ref=cm_sw_r_cp_apa_i_cMr5CbQ767XME
It's not that great
ok it's been confirmed it is some sort of misting device since this machine humidifies the air with water from a reservoir.
❆【EASY TO USE】 : Simply pour the water into the tank, connect it to the USB port. Once switched on, the 750ml water produces humid air and it can operate for up to 8 hours. Mini size and portable is convenient for you to use anywhere
