Hello
Could someone help me Id this component can't find it anywhere, looks like a mosfet? Device is 4468 ga9p13 trying to repair this device so Maby its been discontinued and there is an alternative maby
Thank you.
There are the same modules on cheap china chargers, you can buy one and exchange modules.
https://aliexpress.com/item/1005001558185363.html
Hi.
Are you sure it is defective ?
Your guess may be correct, with pins 1,2,3 tied together, pins 5,6,7 and 8 tied together and pin 4 as the gate.
You might want to order this pcb holding that part (click!).
It seems to be available from some Indonesian site for a small fraction of that price.
If it is the culprit on your PCB, you could consider desoldering it from that charger so you could use it as a replacement on your PCB.
The component itself looks like this: http://www.aosmd.com/res/markings/AO4468.pdf
I had to brighten the image by + 4.5 stops to see the logo.
Edit:
Replacement recommended by A&O : AOSP32320C
Nice find, 6v6gt
Never heard of that company and so it's logo before.
AO4468 heavily advertised on Aliexpress.
thanks very much i did see the logo but never seen it before
