I am in desperate need to identify this motor so that I can attempt to find one w/ nearly identical specs and size or at least know that I should stop looking and give up. The numbers on the motor are meaningless as far as I can tell. In the pictures I have drawn the resistances I’ve measured and how each pin is connected to the coils. There is also a picture of one still in the printer laser unit it came out of and one that has been disassembled. If there’s anyone out there that can help me I would really appreciate it (by the way, the number of “triangular teeth” around the circumference of the rotor is 48. 96 if you count both rows).
24 teeth each side for each phase, therefore 4x24 = 96 step motor. Fairly large diameter, which it has
to be to have so many steps, which helped find a few candidates using google image search
OK, I think you need to explain to us just what you propose to do?
Find a replacement for a printer? How much did the printer cost? Nowadays, with very rare exceptions, replacement parts are simply unavailable. What the printer cost will be the price of the replacement.
