Help identifying a starter kit
I got this starter kit years ago and I'm trying to find a manual online. The box doesn't have any branding so it's hard for me to identify. I need the manual because I don't know what several of the parts in the kit do.
sticker doesn't fit on its outline. such "Kits" have no manual. Use contained thing as if it not in Kit.
Welcome to the forum.
Show all the parts, so we can tell what they are.
Thank you for the quick reply! I'd love if you can identify the names of these parts so I can google them:
https://1drv.ms/u/s!AmlcAT3fZ-b0zpVQ6Bs2pEDuwlMWMg
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Top to bottom.
LCD display with parallel interface, takes a lot of pins s to drive.
Looks like a Bluetooth module.
A PIR movement sensor the type used in burglar alarms.
A monochrome OLED display, using an I2C interface. Probably 128 by 64 bit resolution.
It´s an HC-06.
Since all the pins are soldered, I think the LCD display has a I2C backpack.
Probably an HC-SR501 Pir Motion IR Sensor.
Yes, indeed it is.
