Help identifying and correcting avrdude errors during uploading to Mega
I am attempting to build a baseball scoreboard for my grandson's ball team, and would like some assistance with the avrdude errors I am getting. I am modifying a sketch I got from the wikispaces website for IR Remote control of LEDs. The sketch looks promising. I replaced the IR codes with those from my remote and I get the following when I attempt to download to a new 2560 Mega: avrdude: stk500v2_recv(); checksum error (I am getting several lines with this and one with timeout error). I am also getting: avrdude: verification error, first mismatch at byte 0x1d3f, on the next line: 0xc0 ! = 0x02. And the final line has: avrdude: verification error: content mismatch.
I am a novice with the coding and would appreciate any help offered.
I have seen cases where people have 3 exclamation points in a row in their code, and it causes uploading problems. Do you have !!! somewhere in your sketch?
Are you able to upload other sketches to your Mega board?
DavidE8:
Verification error while serial uploading via Arduino bootloader?
Did you try rebooting the PC before trying to upload the sketch?
Did you try with a different USB cable?
Can you post the full text of the errors you get? There are lots of errors with different causes that look very similar - so you should always post the full text of any and all error messages (this applies to all manner of computer problems, not just Arduino)
dmjlambert:
That causes a different error, I think...
DavidE8:
checksum error
timeout error
verification error
These sound like communications errors. Are there any wires connected to Pin 0 or Pin 1? Does it work if you remove everything but the USB cable?
