i have new components set and i have no idea what one of the components are so i need help...
Welcome to the forum
Please post a photo that is in focus and with some indication of the component size
Sorrty, but your photo is too blurry , try to make another one clearer
Are there no markings on it?
Does not look like an Arduino 101 .................
My guess is that it is a tilt switch.
Did it come with a list of contents? Maybe you can identify everything else and thus use the process of elimination to determine what this one is.
ill try
no markings:(
i had to pick a topic...
no list...
You did not choose very wisely
Your topic was MOVED to its current forum category as it is more suitable than the original
the only thing i know is that it makes a noice when shaked...
which topic chould i choose
I have already moved it to General Electronics as it has nothing to do with a particular Arduino board
ok thanks!
Hi, @mukuk
Welcome to the forum.
Can you please post a link to where you purchased the "components set"?
How big is it?
Can you post an image with it next to a ruler, to show size?
Thanks.. Tom...
PS. If you are using a phone camera, see if it has a "macro" setting, usually a flower symbol.
my bad the set is not newly perchased and i dont have the link ill try to find it...
What else did you get in the set?
Tom....
transisters,resisters, cepasiters, photo resisters,thermisters,etc.
Check the continuity with a Multimeter.
With the object stationary.
With the object moving and making a 'noice'.
