Help identifying correct LCD and Ir2 for project
I'm duplicating a project and want to make sure I'm picking the correct LCD and IR2.
Here's the link to the 16x2 I2C LCD below - is this the same type of LCD identified in the attached schematic? I believe yes but looking for agreement.
http://www.oddwires.com/16x2-lcd-display-with-i2c-interface/?gclid=CPmWvoTtrtQCFRRYDQod1kEKDQ
Here's a link to IR2 control. Again - is this iR2 kit correct per the attached schematic?
https://www.amazon.com/C-J-SHOP-Infrared-Wireless-Control/dp/B01EE4VXS0/ref=sr_1_8?ie=UTF8&qid=1496946089&sr=8-8&keywords=IR+Infrared+Wireless+Control+Sensor
here's the project I'm duplicating..The photo in step 2 shows the schematic.
If the replacement parts have the same pin names and operating voltage, they may be usable. But even then IR sensors can have a different sensitive wavelength or carrier frequency, and I2C devices can have different addresses and can implement a different protocol.
IR control should work if you use a set of control+receiver, which then should work on the same wavelength and carrier frequency.
For LCD displays a number of controller chips exist, so that your replacement part should use the same controller. Otherwise you'll have to change the code, for sending the right (controller specific) commands and data to the right controller address.
Yes, the parts you selected are the same. The same company you selected the LCD from also has the IR parts too.
http://www.oddwires.com/ir-remote-control-includes-ir-reciever-module-and-led/
Unless you're in a hurry, you can get the same exact things on eBay for about 1/4 the cost with free shipping. Of course it takes a couple of weeks to arrive from China :smiley:
Great. thanks for the replies.
avr_fred:
Actually there is no way to know if the i2c lcd backpack matches the one used in the project.
There are many different vendors that make these backpacks and they are not all made the same way.
Many can look the same even when they are not.
The project code appears to be using fm's newLiquidCrystal library so it can work with any of them; however,
if the i2c backpack does not exactly match the one used in the project, the project sketch code will have to be modified to match the backpack being used.
These things can change:
i2c address, pin mapping, backlight control.
The parameters to the LiquidCrystal_I2C constructor provide this information to the library.
If the parameters are incorrect for the specific backpack being used, it will not work.
While not terribly difficult to figure out it can be a real challenge depending on a persons technical expertise.
As an alternative, I'd recommend using my hd44780 library package instead.
It can quickly and easily be installed using the IDE library manager.
It auto-detects everything so it is much easier to use. It will automatically detect the i2c address, pin mapping and backlight control active level.
This allows to you use any cheap i2c lcd backpack and not care about its i2c address or how it is internally made and wired up to the lcd signals or backlight.
It is also faster than the other i2c backpack libraries.
You can read more about it here: GitHub - duinoWitchery/hd44780: Extensible hd44780 LCD library
The i/o class for i2c backpacks is called hd44780_I2Cexp.
It includes examples including a diagnostic sketch (I2CexpDIag) that will test your i2c signals and the internal LCD RAM to make sure that the library and lcd device are properly communicating.
The modifications to the project sketch code are very minimal.
You will need to make come some changes and fix a few bugs that are in that code as well.
In fact most of the changes are because the sketch code has some bugs in it.
For example, the code is using the old constructor which requires using the obsolete lcd.setBacklightPin() pin function.
With the proper constructor declaration, this is not necessary.
Also,
 lcd.setBacklight(HIGH);
is just plain wrong.
setBacklight(dimlevel) is for setting dimming level.
Since HIGH is set to 1, setBacklight(HIGH) asking the device to set the backlight level to 1 which is as dim as possible.
In this case, it is only working because the library made the decision to turn on the backlight when dimming was asked for when dimming is is not supported.
My suggesting is to fix the code to use the proper constructor and API function calls, even if you don't use my hd44780 library.
But of course my recommendation would be to switch to hd44780 and get an easier to use solution that is also faster.
To switch to hd44780 all you have to do is:
  • change the header files included to use the two hd44780 header files.
  • change the constructor to a simpler one for hd44780_I2Cexp that will never change for any backpack
  • only use lcd.begin(cols, rows) for initialization.
  • use backlight(), noBacklight() if you want to turn backlight on/off.
    begin() will automatically turn the backlight on.
See the included examples for the hd44780_I2Cexp i/o class for which header files to use and how to declare the lcd object.
--- bill
well, I connected the IR receiver and the LCD to the project. I used a TV remote and tried volume up/down, TV, Mute - no response from the project. No output to the display - it lights up but no text.
I ran a test IR sketch, no response - using the remote that came with the receiver and a random TV remote laying around the house.
Havent tried Bill's suggestions for the display.
Ugh. why oh why dont things just work?
Incase I connected something incorrectly, how sensitive are they ? I would think the IR receiver wouldnt care too much.
just an update - I am now able to suddenly get a response from the IR receiver and out put to the serial monitor.
however for the project, the IR receiver seems to start working (led blinks on the ir receiver and on the arduino when I push buttons on the remote) then the IR receiver seems to hang, the LED stays bright and no other response until I remove / return power.
still no output from the display.
I'm going to move this discussion to a new thread.. since I have the components now need to get them to function properly. thanks.
