Help identifying electronic components
Hi I'm trying to repair and hack a boot dryer, but I can't make sense of the circuit yet, for that I need help identifying this two electronic components that were jammed into the heating element:
Component 1:
Component 2:
What are this things?
Thanks a lot!!
Thermo disconnect.
LarryD:
Thermo disconnect.
Thanks! I guess you refer to the second one. Is that right?
Can you measure the resistance between th terminals , disconnected from the circuit.
First one looks like a thermal fuse which melts with heat.
Second one i do not know , but could be self reseting.
Thanks for your help!
Component 1 turned out to be a termal cutoff like this one, and the second is a bimetal thermal switch like this one.
Cheers
Aupo thermal fuse: http://aupo.manufacturer.globalsources.com/si/6008800550074/Showroom/3000000157562/15686/Thermal-cutoff.htm
