Help Identifying I2C Sensor from Propel Star Wars Drone
I have a sensor from a Propel Star Wars drone that I can't identify. The metal part of the sensor is marked with "A6103 040". I have tried various libraries and sensors, including BME280, BMP280, BMP388, BME680, MPU6050, MS5611, HTU21D, LPS22HB, and MS8607, but none have worked. Does anyone have an idea what sensor this could be or has experience with similar sensors used in Propel drones?
The sensor has an I2C address of 0x76 and shows the following register values:
Register Value
0x00 0xCA
0x01 0x4E
0x02 0xA4
0x03 0x21
0x04 0xD0
0x05 0xBC
0x06 0x03
0x07 0x83
0x08 0xC7
0x09 0x00
0x0A 0x00
0x0B 0x00
0x0C 0x00
0x0D 0x10
0x0E 0x00
0x0F 0x00
0x10 0x0D
0x11 0x0E
0x12 0xFA
0x13 0x12
0x14 0xDE
0x15 0xBF
0x16 0x36
0x17 0x35
0x18 0xF4
0x19 0xFB
0x1A 0x04
0x1B 0x3E
0x1C 0xDF
0x1D 0xEB
0x1E 0x00
0x1F 0x3C
0x20 0xFC
0x21 0x2B
0x22 0x00
0x24 0x20
0x25 0x57
0x26 0x62
0x27 0xA6
0x28 0x32
0x29 0x00
0x2A 0x00
0x2B 0x00
0x2C 0x00
0x2D 0x00
0x2E 0x00
0x2F 0x00
0x30 0x61
0x31 0x14
0x32 0x02
0x33 0x66
0x34 0x97
0x35 0x0D
0x36 0x00
Thank you for any help!
Best regards,
Halit
Here are some photos of the sensor and the board:
Looks like a BMP180 pressure sensor. Altimeter?
I agree. The reviews say altitude and speed are limited.
Here is the datasheet for the BMP180. The circuit board looks like the recommended setup with 2 caps.
I have tried multiple libraries and sensors, including BME280, BMP280, BMP388, BME680, MPU6050, MS5611, HTU21D, LPS22HB, and MS8607, but none have worked.
I also tried BMP180 libraries on an Arduino Uno with the unknown sensor. The result was: begin() failed. Check your BMP180 interface and I2C address.
The back of the PCB is labeled: ADF16102C ST-V2 20161010. There are only two capacitors and the sensor itself.
Hey, I discovered that the sensor is an SPL06-001.
I can read some values and altitudes:
20:22:58.391 -> Measured Air Pressure: 979.22 mb
20:22:58.391 -> Local Airport Sea Level Pressure: 1011.30 mb
20:22:58.391 -> altitude: 271.1 m
20:22:58.391 -> altitude: 889.4 ft
Best regards,
