The parts coming from the floppy are likely to use 12V or 5V, minus the driver drop.
The way I guesstimate the voltage of unknown steppers is apply a voltage to 2 windings out of the 4 available and wait for the temperature rise. Then I slowly increase voltage until the temperature stabilizes around 70C (some steppers can take more but without a datasheet it's best to keep a safety margin).
You can probably use this technique for the solenoid/dc motor, maybe with lower temperature rise.
semicolo:
So they don't usually regulate the 12V down to something lower? OK, good.
semicolo:
Good idea to test via temperature, thanks. I am confused about the stepper, I thought they had 2 windings, not 4 - also the big one has 5 wires to add to the confusion.
Managed to find a page that details the typical stepper found in old 5.25" drives here Jones on A Worked Stepping Motor Example - It even has the wiring colour codes and typical current.
