system
1
Does anyone know what the Vex batter power connector is called?
You can see it here:
http://www.vexrobotics.com/276-1491.html
I tried googling, but can't find any "2 pin molex or amp" connectors. No idea what it its.
I need adapter from Vex power to Arduino (+ some extra wires for motor shield etc...).
Any help much appreciated!
P.S.: The best approximation I could find was this, but its not right either:
Are you specifically requiring these connectors or are you able to use other type of high current connector in its place?
If you need simply a connector that you can use in place of the ones attached, have a look at XT60 connectors. Lots of amps and inexpensive.
Weedpharma
These are called Tamiya connectors. Pretty standard connector for Nicad/Nimh battery packs.
Tamiya-Plug-Set-with-Male-and-Female-Connectors
I found some of these connectors at my local hobby shop.
-transfinite
