the problem is, I cannot seem to find (or understand) codes that I may need.
what I would like to do is:
if sensorvalue <=100 , then it should do this: digitalWrite(relaypin, HIGH) continous if condition is still true, then if condition turned false, it will start count 12seconds before it goes LOW or off.
I hope I have explained the logic clear enough. Thanks in advance!
BTW, is it okay to use delay() here? I mean, would it affect other tasks?
if (sensorvalue <= 100)
digitalWrite(relaypin, HIGH);
while (sensorvalue <= 100)
// Must update or the loop will never end
sensorvalue = ReadSensorValue();
delay(12000); // Wait 12 seconds
digitalWrite(relaypin, LOW);
Thanks for the inputs masters. After watching videos and doing trial and errors, I managed to crack it. I ended up mastering the millis function and found myself replacing all the delay functions with millis. It was cool!
Jaus2s:
Very good! For all but the simplest sketches, using a state machine model and millis() instead of delay() is the right way to do it.
