Hello, i want to make buttons to alter hours and minutes(set). I used debounce, but i click and i still get not by one hour, but random..
Rele means relay(to create ticking)
VAlanda = hour
Minute = minute
For my easier finding i made in my language(lithuanian)
So can you help me with the hour setting? Thanks.
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <TFT_ILI9163C.h>
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define __CS 10
#define __DC 9
#define __RST 12
Teensy 3.x can use: 2,6,9,10,15,20,21,22,23
Arduino's 8 bit: any
DUE: check arduino site
If you do not use reset, tie it to +3V3
int valandos = 8;
int minutes = 7;
int rele = 6;
int minuteState = 0;
int valandaState = 0;
int lastButtonState = LOW;
int lastButtonState2 = LOW;
long debounceDelay = 1000;
long lastDebounceTime = 0;
long debounceDelay2 = 1000;
long lastDebounceTime2 = 0;
TFT_ILI9163C tft = TFT_ILI9163C(__CS, __DC, __RST);
uint16_t ccenterx,ccentery;//center x,y of the clock
const uint16_t cradius = 63;//radius of the clock
const float scosConst = 0.0174532925;
float sx = 0, sy = 1, mx = 1, my = 0, hx = -1, hy = 0;
float sdeg=0, mdeg=0, hdeg=0;
uint16_t osx,osy,omx,omy,ohx,ohy;
uint16_t x0 = 0, x1 = 0, yy0 = 0, yy1 = 0;
uint32_t targetTime = 0;// for next 1 second timeout
uint8_t hh,mm,ss; //containers for current time
void drawClockFace(){
// tft.fillCircle(ccenterx, ccentery, cradius, YELLOW);
// tft.fillCircle(ccenterx, ccentery, cradius-4, BLACK);
// Draw 12 lines
for(int i = 0; i<360; i+= 30) {
sx = cos((i-90)*scosConst);
sy = sin((i-90)*scosConst);
x0 = sx*(cradius-4)+ccenterx;
yy0 = sy*(cradius-4)+ccentery;
x1 = sx*(cradius-11)+ccenterx;
yy1 = sy*(cradius-11)+ccentery;
tft.drawLine(x0, yy0, x1, yy1, YELLOW);
static uint8_t conv2d(const char* p) {
uint8_t v = 0;
if ('0' <= *p && *p <= '9') v = *p - '0';
return 10 * v + *++p - '0';
void setup(void) {
tft.begin();
tft.setTextColor(WHITE, BLACK);
ccenterx = tft.width()/2;
ccentery = tft.height()/2;
osx = ccenterx;
osy = ccentery;
omx = ccenterx;
omy = ccentery;
ohx = ccenterx;
ohy = ccentery;
drawClockFace();// Draw clock face
//get current time from compiler
hh = conv2d(__TIME__);
mm = conv2d(__TIME__+3);
ss = conv2d(__TIME__+6);
pinMode(rele, OUTPUT);
pinMode(valandos, INPUT_PULLUP);
pinMode(minutes, INPUT_PULLUP);
targetTime = millis() + 1000;
void drawClockHands(uint8_t h,uint8_t m,uint8_t s){
// Pre-compute hand degrees, x & y coords for a fast screen update
sdeg = s * 6; // 0-59 -> 0-354
mdeg = m * 6 + sdeg * 0.01666667; // 0-59 -> 0-360 - includes seconds
hdeg = h * 30 + mdeg * 0.0833333; // 0-11 -> 0-360 - includes minutes and seconds
hx = cos((hdeg-90)*scosConst);
hy = sin((hdeg-90)*scosConst);
mx = cos((mdeg-90)*scosConst);
my = sin((mdeg-90)*scosConst);
sx = cos((sdeg-90)*scosConst);
sy = sin((sdeg-90)*scosConst);
// Erase just old hand positions
tft.drawLine(ohx, ohy, ccenterx+1, ccentery+1, BLACK);
tft.drawLine(omx, omy, ccenterx+1, ccentery+1, BLACK);
tft.drawLine(osx, osy, ccenterx+1, ccentery+1, BLACK);
// Draw new hand positions
tft.drawLine(hx*(cradius-28)+ccenterx+1, hy*(cradius-28)+ccentery+1, ccenterx+1, ccentery+1, YELLOW);
tft.drawLine(mx*(cradius-17)+ccenterx+1, my*(cradius-17)+ccentery+1, ccenterx+1, ccentery+1, YELLOW);
tft.drawLine(sx*(cradius-14)+ccenterx+1, sy*(cradius-14)+ccentery+1, ccenterx+1, ccentery+1, YELLOW);
tft.fillCircle(ccenterx+1, ccentery+1, 3, YELLOW);
// Update old x&y coords
osx = sx*(cradius-14)+ccenterx+1;
osy = sy*(cradius-14)+ccentery+1;
omx = mx*(cradius-17)+ccenterx+1;
omy = my*(cradius-17)+ccentery+1;
ohx = hx*(cradius-28)+ccenterx+1;
ohy = hy*(cradius-28)+ccentery+1;
valandaState = digitalRead(valandos);
minuteState = digitalRead(minutes);
// read the state of the switch into a local variable:
int reading = digitalRead(minutes);
int reading2 = digitalRead(valandos);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if (reading2 != lastButtonState2) {
lastDebounceTime2 = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading != valandaState) {
valandaState = reading;
// only toggle the LED if the new button state is HIGH
if (valandaState == LOW) {
hh++;
if ((millis() - lastDebounceTime2) > debounceDelay2) {
if (reading2 != minuteState) {
minuteState = reading2;
if (minuteState == LOW) {
mm++;
lastButtonState2 = reading2;
lastButtonState = reading;
if (targetTime < millis()) {
targetTime = millis()+1000;
ss++;
rele = !rele;
if (ss == 60) {
ss = 0;
mm++;
if(mm > 59) {
mm = 0;
hh++;
if (hh > 23) hh = 0;
drawClockHands(hh,mm,ss);
