Hello all,
So I have a solenoid that I'm turning on and off using Arduino. I also have a Hall effect sensor that is reading positioning. What I want to do is turn the solenoid permanently off if the piston moves past a certain point.
I already have the solenoid and hall effect sensor working, I just need to implement the last part.
I am trying to get it to work by adding another if statement that is added in as a comment. I'm wondering if this is the best way to do this or if there is another approach I should go with.
Thanks!
#include "HX711.h"
#define calibration_factor -11440.0 //This value is obtained using the SparkFun_HX711_Calibration sketch
#define DOUT 3
#define CLK 2
HX711 scale(DOUT, CLK);
int solenoid = 13;
int TOMILLIGAUSS = 977;
int NOFIELD = 507;
const unsigned long solenoidInterval = 4500;
const unsigned long hallInterval = 200;
unsigned long solenoidTimer = 0;
unsigned long hallTimer = 0;
int solenoidState = LOW;
pinMode(solenoid, OUTPUT);
solenoidTimer = millis();
hallTimer = millis();
Serial.println("HX711 scale demo");
scale.set_scale(-11440.0); //This value is obtained by using the SparkFun_HX711_Calibration sketch
scale.tare(); //Assuming there is no weight on the scale at start up, reset the scale to 0
Serial.println("Readings:");
void DoMeasurement()
// measure magnetic field
int raw = analogRead(0); // Range : 0..1024
// Uncomment this to get a raw reading for calibration of no-field point
Serial.print("Raw reading: ");
Serial.println(raw);
long compensated = raw - NOFIELD; // adjust relative to no applied field
long gauss = compensated * TOMILLIGAUSS; // 1000; // adjust scale to Gauss
Serial.print(gauss);
Serial.print(" milliGauss ");
if (gauss > 0) Serial.println("(South pole)");
else if(gauss < 0) Serial.println("(North pole)");
else Serial.println();
//DoMeasurement is used to read and print data from the Hall effect sensor
//Measurements will be taken every second
if( (millis() - solenoidTimer) >= solenoidInterval) {
//if statement for if the hall effect reads a certain number or more to stop
if (solenoidState == LOW)
solenoidState = HIGH;
//Write new state
digitalWrite(solenoid, solenoidState);
//Reset timer
if( (millis() - hallTimer) >= hallInterval) {
DoMeasurement();
Serial.print("Reading: ");
Serial.print(scale.get_units(), 1); //scale.get_units() returns a float
Serial.print(" lbs"); //You can change this to kg but you'll need to refactor the calibration_factor
