Help in automatic speed-based lights. EDIT (Receiving a compiling error, solved)
Hi guys! This is my first ever post here and my first ever program, so bear with me.
I'm trying to turn on a light by using an infrared sensor to find the speed of a car, and turn on a light if it is speeding to let the driver know.
I * a cough* tried cough :fearful: :o to write a code, but it is not working(getting a "expected '(' before ';' token' error") and I need some help.
Here is my code:
int timer=0;
int IRPin=9;
int obstacle=HIGH;
int T;
int MS;
int LED=5;
int KMPH;
unsigned long currentMillis;
pinMode(IRPin, INPUT); //Defining inputs and outputs
pinMode(LED, OUTPUT);
if (obstacle == LOW;) {  //Means there is an obstacle
  currentMillis = millis(); //Start timer
if (obstacle == HIGH;){ //No more obstacle
MS=40/currentMillis; //Divide current time and pre-set distance to get meters per second
KMPH=MS*3.6; //convert to KMH
if (KMPH >= 40){
  digitalWrite(LED, HIGH);
All help appreciated, thanks in advance!
EDIT: Added my error name, as I forgot to.
 if (obstacle == LOW;) {  //  );  semicolon ends statement Should be );
} // this bracket ends the loop() function.   Remove it
if (obstacle == HIGH;) // same error as before  Should be );{ //No more obstacle
Fix those errors and it will compile. Whether it does what you want or not, I don't know.
If your code will not compile, say so. The hated phrase "it does not work" conveys no useful information.
groundFungus:
Thanks a lot! It compiled. Whether it works or not, will have to wait till a receive my sensor shipment.
As for the 'does not work', sorry about that! I completely forgot. I've added it now, and I will post an update on whether it works.
Once again, thanks!
