Help in coding
hello friends,i am looking for some help in modifying a code for a arduino base rover that use a ps2 remote…i have this code:
PS2Controlv0.ino
21 September 2015
Hamish Trolove - www.techmonkeybusiness.com
This sketch illustrates the use of a Playstation 2 Controller to
actuate a series of servos and an Electronic Speed Controller (ESC)
as you might do with a vehicle. An LED light is used to illustrate
the use of the Playstation 2 Buttons.
Pin assignments are:
3.3V output to PS2 red pin
5V output to 1Kohm pull up resistors for PS2.
Pin D02 to PS2 brown pin (data)
Pin D03 to PS2 yellow pin (attention)
Pin D04 to PS2 orange pin (command)
Pin D05 to PS2 blue pin (clock)
Pin D06 to ESC Signal Pin
Pin D07 to Steering Servo Signal pin
Pin D08 to Servo 1 Signal pin
Pin D09 to Servo 2 Signal pin
Pin D13 to LED Transistor Base
The ESC servo connection supplies 5.6V to the servos.
The coding pulls on the PS2X library developed by Bill Porter.
See www.billporter.info for the latest from Bill Porter and to
download the library.
The controls used for this sketch are;
Right Stick - X-axis = Steering Servo left/right, Y-axis = ESC forward/backward
Left Stick - X-axis = Servo 2 left/right, Y-axis = Servo 1 left/right
Triangle = Toggle the LED
#include <Servo.h> //For driving the ESCs and Servos
#include <PS2X_lib.h> // Bill Porter’s PS2 Library
PS2X ps2x; //The PS2 Controller Class
Servo SteeringServo; //Create servo object representing SteeringServo
Servo ServoN1; //Create servo object representing Servo 1
Servo ServoN2; //Create servo object representing Servo 2
Servo ESCcontrol; //Create servo object representing ESC
const int LEDpin = 13; //green LED is on Digital pin 13
volatile boolean LEDHdlts; //LED headlights on/off toggle
int PlyStnRStickUpDn = 0; //Value read off the PS2 Right Stick up/down.
int PlyStnRStickLtRt = 0; //Value read off the PS2 Right Stick left/right
int PlyStnLStickUpDn = 0; //Value read off the PS2 Left Stick up/down
int PlyStnLStickLtRt = 0; // Value read off the PS2 Left Stick left/right
int ESCSetting = 90; //Setting for the ESC (degrees).
int StrServoSetting = 90; //Setting for the Steering Servo
int ServoN1Setting = 90; //Setting for the Servo 1
int ServoN2Setting = 90; //Setting for the Servo 2
ps2x.config_gamepad(5,4,3,2, false, false);
//setup pins and settings: GamePad(clock, command, attention, data, Pressures, Rumble)
//We have disabled the pressure sensitivity and rumble in this instance.
pinMode(LEDpin, OUTPUT); //Sets the LEDpin to output
LEDHdlts = false; //Sets the Headlights to off
SteeringServo.attach(7);// attaches the Steering Servo to pin 7
ServoN1.attach(8);// attaches the Servo 1 to pin 8
ServoN2.attach(9);// attaches the Servo 2 to pin 9
ESCcontrol.attach(6,150,2250);// attaches the ESC to pin 6
//The ESC attachment command above also includes the signal settings
//for the maximum and minimum that the ESC will recognise. This
//varies for different ESCs.
//Set all ESCs and Servos to a neutral 90 degree position
//this avoids the ESC trying to calibrate.
ESCcontrol.write(90);
SteeringServo.write(90);
ServoN1.write(90);
ServoN2.write(90);
delay(5000); //Five second delay to allow ESC and controller to
// fully initialise.
ps2x.read_gamepad(); //This needs to be called at least once a second
// to get data from the controller.
if(ps2x.ButtonPressed(PSB_GREEN)) //Triangle pressed
LEDHdlts = !LEDHdlts; //Toggle the LED light flag
//Analogue Stick readings
PlyStnRStickUpDn = ps2x.Analog(PSS_RY); //Right Stick Up and Down
PlyStnRStickLtRt = ps2x.Analog(PSS_RX); //Right Stick Left and Right
PlyStnLStickUpDn = ps2x.Analog(PSS_LY); //left Stick Up and Down
PlyStnLStickLtRt = ps2x.Analog(PSS_LX); //Left Stick Left and Right
//Readings from PS2 Controller Sticks are from 0 to 255
//with the neutral being 128. The zero positions are to
//the left for X-axis movements and up for Y-axis movements.
//Variables to carry the settings for the ESCs and Servos
//The values from the PS2 Sticks are mapped to 0 to 180 degrees
ESCSetting = map(PlyStnRStickUpDn,-256,256,0,179);
StrServoSetting = map(PlyStnRStickLtRt,-256,256,0,179);
ServoN1Setting = map(PlyStnLStickUpDn,-256,256,0,179);
ServoN2Setting = map(PlyStnLStickLtRt,-256,256,0,179);
//Write it to the Servos or ESCs
ESCcontrol.write(ESCSetting);
SteeringServo.write(StrServoSetting);
ServoN1.write(ServoN1Setting);
ServoN2.write(ServoN2Setting);
digitalWrite(LEDpin,LEDHdlts); //Light the LED based on headlights status flag
delay(15);
is from this site:
http://www.techmonkeybusiness.com/using-a-playstation-2-controller-with-your-arduino-project.html
and i wish to put all the buttons from the joystick and i don’t now haw.
please help me :slight_smile:
What have you tried?
I think you should not attempt the entire project in one shot.
Instead, you should break this project down into parts. Just use the PS2 remote. Have it write to the serial monitor.
Can you get it to recognize all the buttons? Some buttons?
Writing to servos - do this as a separate sketch. Can you get the servos to respond to the Sweep tutorial?
After that, try to combine them into one sketch.
Edit: use code tags when you post code.
Ok about the code tag....
About the code I used on a project of mine but I wanted to use all the buttons from the joystick....
Any help in making a simple code were I can use all the buttons or help in modifying this one?!
CristianYO8SXT:
No, *this * kind of code tag:
I see that you are using Bill Porter's library for the PS2 controller.
I googled Bill Porter and found a page with his library.
I downloaded it.
It includes a PS2X_Example sketch that shows how to read many buttons from the controller object.
And then it prints the status of those buttons to the serial monitor.
You likely have this sketch in the directory where your library is.
I dropped the library on my desktop just so I could look at it so the path looks like this for me
C:\Users\vherm\Desktop\madsci1016-Arduino-PS2X-5d2be70\PS2X_lib\Examples\PS2X_Example
See if you can find this example, load it on your board and run it.
Does it show results when you push the other buttons?
Can you find the relevant lines of code that read those buttons?
Let us know how far you get with this or if you run into problems.
i have the library for ps2 in the programming software...i don't now haw to code so i am looking a simpla way to use all the buttons from the ps2 joystick as a normal on/off swich and the arrows for the servo like in the code i posted...hope is not a problem but i hope someone can modify/write a code to do the things i write up..... :slight_smile:
CristianYO8SXT:
Oi!
So you have coding requests that you want to make those requests, and you want other people to write the code for you, correct?
CristianYO8SXT:
This is a good time to learn. You are in a forum full of people who help others learn better coding.
And if you want someone to write the code for you, we do that too! Just jump on over to Gigs and Collaborations and negotiate the price for how much you will pay to have the coding done.
But this is something you can learn. Take it slow and take small steps. Go push the blink tutorial on to your board and see the LED blink.
Change the code to make it blink differently and see the LED blink differently.
We can get you there. If you try.
Or you can pay someone to do it for you.
ok....I thought that i get some help in modifying the code that i posted....i don't wanth to make money ...or to give...some things i think they need to be free...like a helping hand.
this is my last post.
CristianYO8SXT:
ok…I thought that i get some help in modifying the code that i posted…
That is what I am trying to do.
some things i think they need to be free…like a helping hand.
Yes, I agree with you.
I am sorry to hear that. I wonder if you misunderstood my attempts to help you.
