Help in connecting siemens c55 to MYSQL server
Hello
I need your help in my final year project
I want to deliver data from siemens c55 GPRS modem to MYSQL database ... the GPRS modem is connected to arduino atmega 2560 .
So is there any tutorial or any thing that demonstrate this issue ???
Thanks in advance
No but it is not difficult, you just never did it, these are the steps to be taken
1) Add an ethernetshield to the ATMEGA 2) install APache and PHP on the system with MySQL server 3) make a HTTP POST message from the Arduino to the PHP Apache, 4) PHP will store it into MySQL
Alternative Should also be possible over a serial line, but I have no experience with PHP and Serial . [The integration between PHP and MySQL is very good]
Al these code-parts can be found on this forum, as I have seen them pass by, so you only need to search and combine...
succes,
