Hi, im want create mask to enable LPF2 ( ODR_XL/400 )
But I can't create the bitmask correctly.
CTRL8_XL(17h)
Datasheet:
https://www.st.com/resource/en/datasheet/lsm6ds3.pdf
Thanks for help !
CTRL8_XL(17h)
Datasheet:
Thanks for help !
HPCF_XL[1:0] = 0b11
To enable:
High-pass filter: ODR_XL / 400
and
LPF2: ODR_XL / 400
I do: 0b10000001 | 0b11 | 0b11
is it correct?
No - why would you OR something twice, in the wrong two bits?
You need to shift your mask left before ORing.
You can give an example ? . I do not understand.
If you look at the description of the CTRL8_XL register (Section 9.19, Table 66), you'll see that HPCF_XL occupies bits 6 and 5 of the register.
So, your mask needs to be shifted left 5 bits.
(Caveat: I have never used this device)
