Help in programming Up / Down Counter
Good Day Everyone;
I am working one making up / down counter using two RFIDs (https://www.sparkfun.com/products/8419) and LED Matrix (16x24 Red LED Matrix Panel - Chainable HT1632C Driver : ID 555 : $24.95 : Adafruit Industries, Unique & fun DIY electronics and kits) I did successfuly program the first RFID and Led matrix and I am stick in connecting the second one and make the down counter could someone guide me on that. The code as below:
#include "HT1632.h"
#define DATA 2
#define WR   3
#define CS   4
#define CS2  5
int scrwrt =0;
int newtag =0;
// use this line for single matrix
HT1632LEDMatrix matrix = HT1632LEDMatrix(DATA, WR, CS);
int RFIDResetPin = 13;
//Register your RFID tags here
char tag1[16] = "50008FF398B4";
char tag2[16] = "5000B98D6206";
void setup(){
//Serial1.begin(9600);
  matrix.begin(HT1632_COMMON_16NMOS);
  matrix.fillScreen();
  matrix.clearScreen();
  pinMode(RFIDResetPin, OUTPUT);
  digitalWrite(RFIDResetPin, HIGH);
  matrix.print("on..");
  matrix.writeScreen();
void loop(){
  char tagString[13];
  int index = 0;
  boolean reading = false;
  if (scrwrt > 0)
  matrix.setTextSize(1);    // size 1 == 8 pixels high
  matrix.setTextColor(1);   // 'lit' LEDs
  matrix.setCursor(0, 0);
  if (scrwrt==1)
  matrix.print("no");
  matrix.setCursor(0, 8);   // next line, 8 pixels down
  matrix.print("ident");
  if (scrwrt==2)
  matrix.print("emp:");
  matrix.print(tagString);
  if (scrwrt==3)
  matrix.print("stu:");
  scrwrt=0;
clearTag(tagString); //Clear the char of all value
  while(Serial.available()){
    int readByte = Serial.read(); //read next available byte
    if(readByte == 2) reading = true; //begining of tag
    if(readByte == 3) reading = false; //end of tag
    if(reading && readByte != 2 && readByte != 10 && readByte != 13){
      //store the tag
      tagString[index] = readByte;
      index ++;
    scrwrt=1;
  checkTag(tagString); //Check if it is a match
  resetReader(); //eset the RFID reader
void checkTag(char tag[]){
//Check the read tag against known tags
  if(strlen(tag) == 0) return; //empty, no need to contunue
  if(compareTag(tag, tag1)){ // if matched tag1, do this
    lightLED(2);
Serial.print("studant : ");
scrwrt =2;
  }else if(compareTag(tag, tag2)){ //if matched tag2, do this
    lightLED(3);
Serial.print("employee : ");
scrwrt=3;
else{
  Serial.print("unknown : ");
Serial.println(tag);
void lightLED(int pin){
//Turn on LED on pin "pin" for 250ms
  Serial.println(pin);
  digitalWrite(pin, HIGH);
  delay(250);
  digitalWrite(pin, LOW);
void resetReader(){
//Reset the RFID reader to read again.
  digitalWrite(RFIDResetPin, LOW);
  delay(150);
void clearTag(char one[]){
//clear the char array by filling with null - ASCII 0
//Will think same tag has been read otherwise
  for(int i = 0; i < strlen(one); i++){
    one[i] = 0;
boolean compareTag(char one[], char two[]){
//compare two value to see if same,
//strcmp not working 100% so we do this
  if(strlen(one) == 0) return false; //empty
  for(int i = 0; i < 12; i++){
    if(one[i] != two[i]) return false;
  return true; //no mismatches
You have done quite some good work, still some remarks to improve coding style.
remove the bulk of code from loop by defining 2 functions e.g. updateDisplay() and checkSerial(). loop could become something like:
#define WAINTING 1
#define READING 2
etc
int state
  state = WAITING
  switch(state)
    case WAITING:
      if (cardDetected()) state = READING;
    case READING:
      readSerial();
      if (strlen(input) == 12) state = READ;
    case READ:
      if (checkTag(input, tag1)) state = EMP;
      if (checkTag(input, tag2)) state = STU;
    case EMP:
      increase(var);
      state = WAITING;
    case STU:
      decrease(var);
      state = WAITING;
  updateDisplay(state);
other functions
in the code above the loop is mostly controlling the state machine.
