help in relay !
i make my arduino uno r3 detect the water level in my water tank, so now i want my pump work when the level is low so i buy yasterday one relay with driver, 5v * 220v 10A,
i know how to connect the pump to the relay,
but i dont know how i will connect it to the arduno
other thing i need help with the code, where i will add the code to make the pump work at 50 % and turn it off when the tank is 100% ?!
this is my code :slight_smile: you can share it :stuck_out_tongue:
#include <LiquidCrystal.h>
#define ECHOPIN 3                            // Pin to receive echo pulse
#define TRIGPIN 4                            // Pin to send trigger pulse
#define STATUSPIN 13                        // Use for troubleshooting
int highWater = 20;        // These values allow to calculate % of full
int lowWater = 100;        // SRF04 hangs above water (lower distance = more water)
byte symbol[8] = {         // Custom character for LCD display
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B00000,
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);    // Assign pins
// Utility function for flashing STATUSPIN
void flashLed(int pin, int times, int wait) {
  for (int i = 0; i < times; i++) {
    digitalWrite(pin, HIGH);
    delay(wait);
    digitalWrite(pin, LOW);
    if (i + 1 < times) {
      delay(wait);
  lcd.begin(16,2);
  lcd.print(" AQUA LEVEL ");
  lcd.createChar(0, symbol);
  pinMode(ECHOPIN, INPUT);
  pinMode(TRIGPIN, OUTPUT);
  delay(3000);       // Show application name for 3 seconds.
  // Measure distance
  digitalWrite(TRIGPIN, LOW);                   // Set the trigger pin to low for 2uS
  delayMicroseconds(2);
  digitalWrite(TRIGPIN, HIGH);                  // Send a 10uS high to trigger ranging
  delayMicroseconds(10);
  digitalWrite(TRIGPIN, LOW);                   // Send pin low again
  int distance = pulseIn(ECHOPIN, HIGH);        // Read in times pulse
  distance= distance/58;                        // divide by 58 gives cm.
  // Convert measured value to value between 0-16, to display on LCD
  // Use Arduino built-in map and constrain functions
  int scaledValue = map(constrain(distance, highWater, lowWater), lowWater, highWater, 0, 16);
  lcd.clear();
  lcd.print("Water Level:");
  lcd.setCursor(0,1);
  while (scaledValue > 0) {
     lcd.print((char)0);
     scaledValue--;
   delay(2000);  // Wait 2 seconds before measuring again. We're in no hurry!
It looks like your variable distance has the number of cm to the water surface. Suppose it is 5cm when full and 18cm when half full.
Then you need a little code such as
if (distance >= 18) {
    digitalWrite(relayPin, HIGH); // assumes HIGH switches the relay on
if distance <= 5) {
   digitalWrite(relayPin, LOW);
You can’t connect an electo-mechanical relay direct to an Arduino I/O pin because it can’t supply enough current for the relay coil. You need to use the Arduino to control a transistor which controls the current in the relay coil. I reckon if you Google arduino relay you will get lots of circuit examples. Also, don’t draw power for the relay coil from the Arduino 5v pin - use a separate power source.
…R
i don't know what to say, just you are awesome :blush: i want ask other question :) i make other arduous with same code but i want it for two tanks so i add other ultrasonic sensor on port 5 and 6 if i want show level for two tanks ? how i can made that on the same diplay i will copy the same code to other sensor, but my problem with the display
for the relay i use this one :slight_smile: simple and i think i dont need to add anything on it,
i have a pump 15A for that i used other relay 24V*220V 20A AC , i have other power suply for the second relay , so i think that will work for me :slight_smile:
but not the same its take 5v *220v 10A
this is my relay
http://i01.i.aliimg.com/wsphoto/v0/1453630975_1/wholesales-100pcs-one-channel-Power-Relay-module-12V-high-lever-trigger-SRD-12VDC-SL-C-PCB.jpg
Why are you re-posting the same question?
Mark
you are right i will delete that one :)
narzan: how i can made that on the same diplay
Thank you for your kind comment, but now I have to disappoint you. I have little or no experience with LCD displays.
If you were just diplaying the data on the Serial Monitor I would do it with something like this
Serial.print("Tank A ");
Serial.print(tankOneDepth);
Serial.print("  Tank B ");
Serial.println(tankTwoDepth);
which would give something like Tank A 23 Tank B 34
...R
