I thought that splitting strings was easier than in fact it is. Here is my code:
String inData;
String myArray[2];
inData = "";
if (Serial.available() > -1) {
int h=Serial.available();
for (int i=0;i<h;i++){
inData += (char)Serial.read();
From serial, I am getting and string like: RB,35
the inData var stores the string and than it has to be split into an array like: myArray[0] = RB ; myArray[1] = 35;
So the first data is a word and the second data is a value from 0 to 255.
There is a problem with your original too, they are only copying 1 character, you need two characters per string going off your example. EDIT: can put a read and dump the ',' value when collecting data rather than removing/splitting the data later. This code wont do if the incoming strings are of variable length though.
First study char arrays, will make things more straight forward. There are also alot of character array manipulation functions available, string is not a real good choice.
One more thing - you should make sure there are enough characters in the serial buffer before doing multiple reads.
At the moment you use "if(Serial.available()>-1)". This will always be true, as it returns 0 or more. You should check to see if it is at least as great as the number of characters you want to read before you next to a check on the Serial.available.
If you are expecting a certain sequence it is better to wait for enough data rather than do stuff when anything is available.
if you need two characters per element and 1 for the delimeter ( the ',' character ) then wait until that is available.
After you have enough data start the copy process, maybe verify the ',' is actually an ',' character ( to kind of ensure data is valid ), if so, continue
if you are expecting binary data, 1 byte is all you need to wait for, if it is text then you need to wait for a max of 3 characters.
E.g.
255,255
your incoming data is max seven chars long, wait till available then read data into variables. While reading check for a ',' to determine when to read into the second array element.
does not do what you probably expect. Unfortunately, it's no syntax error
Is it still defined as
String myArray[2];
If you do not follow the rule "No String: they produce more trouble than help" ,
then at least think remember that c_Temp is just a char array, but without terminating 0, so you cannot use it as a string, e.g. to initialize a String object.
Yes it is. The problem is that I don't know how to handle the incoming data. I mean a entire word (e.g. RB) and an hole number (e.g 125) in a 2 positions char array.
Me neither.
You do not know the exact length , right ?
You know it contains two parts, separated by a comma , right ?
How do you know the end ? ( A line end, perhaps 0x0D 0x0A ) ? ( The worst case: "Well, no more characters for half a second". Don't ask for this ???)
I'd use a different approach than pYro_65: store each character as it arrives and act when a delimiter ( ',' , anything not 0..9 or A..Z , any other criteria ?) is found.
Perhaps you skip any bad characters ( space, newline, whatever) in this stage ?
Then replace the delimiter with a 0 ( or add one, if you did not store that delimiter in c_Temp yet )
and use that partial string to build your new String array element.
After a comma it builds array[0], after a different delimiter it builds array[1] , if this is what you want (?)
Your incoming data buffer c_Temp can be reset after each part was processed and just needs the size for one part, plus the '\0'.
Don't write beyond the size of c_Temp!
