help in stream function
hi all, when i try this function this function gives me compile time error "error: 'stream' was not declared in this scope" every time give me the same error can any one help me
  stream.available();
What are you trying to do? You should be using Serial.available(), although just using it as a statement is a bit pointless.
Stream is the base class for character and binary based streams. It is not called directly, but invoked whenever you use a function that relies on it.
