help in using keypad library to my own functioning Usb Midi Keyboard
many many thanks for help in my preveious topic,,,
Now i have tested keypad libray with 2x3 matrix using 6 buttons.
actually i want to make my own functioning Usb Midi keyboard with42keys+ 7 function button..
as there is sketch i have tested & modified from inbuilt example,,,,,
#include <Keypad.h>                                    //  tested
const byte ROWS = 2; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'}
byte rowPins[ROWS] = {1, 0}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {5, 6, 7}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
    if (kpd.getKeys())
    {                 for (int i=0; i<LIST_MAX ;i++)  {
            if   (kpd.key[i].stateChanged  && (kpd.key[i].kstate == PRESSED))
                Serial.print("Key ");
                Serial.print(kpd.key[i].kchar);
                Serial.println("DUBBTA");
                        if   (kpd.key[i].stateChanged  && (kpd.key[i].kstate == RELEASED))
                Serial.println("CHDTA ");
}  // End loop
here are functions ,which i want to understand and use in my sketch.
(1) if my target matrix 7x7 ,,49buttons, (Button1,Button2,Button3,.......Button49)
then what & where should be change in code???????
(2) in loop function , ( If button1 is pressesd/released ,do this ) and ( if button2 is pressed/released
do that ) what changes for assign diffrent functions from different buttons ?????
(3) if button44 is hold and button45 is pressed , do some different,,,,,......for this operation what changes should be done in code??
please help or hint ,,,,,,,,,,,,thank you
charnjit:
(1) if my target matrix 7x7 ,,49buttons, (Button1,Button2,Button3,.......Button49)then what & where should be change in code???????
const byte ROWS = 7; //four rows
const byte COLS = 7; //three columns
// For key codes you can use any number between 1 and 127
{1,2,3,4,5,6,7},
{8,9,10,11,12,13,14},
{43,44,45,46,47,48,49}
byte rowPins[ROWS] = {2, 3, 4, 5, 6, 7, 8}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {9, 10, 11, 12, A0, A1, A3}; //connect to the column pinouts of the kpd
charnjit:
To get the 'released' events you will have to use some advanced features of the Keypad library. See File-Examples->Keypad->MultiKey
charnjit:
To use multiple, simultaneous, keys you will have to use some advanced features of the Keypad library. See File-Examples->Keypad->MultiKey
thank you john wasser,,,,
please check this code ,,,what is wrong with my code
#include <Keypad.h>
const byte ROWS = 7; //seven rows
const byte COLS = 7; //seve columns
{1,2,3,4,5,6,7},
{15,16,17,18,19,20,21},
{22,23,24,25,26,27,28},
{29,30,31,32,33,34,35},
{36,37,38,39,40,41,42},
byte rowPins[ROWS] = {1, 0, 4, 5, 6, 7, 8}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {9, 10, 16, 14, 15, 18, 19}; //connect to the column pinouts of the kpd
    if (kpd.getKeys())
           if   (kpd.key[i].stateChanged  && (kpd.key[i].kstate == PRESSED) && (kpd.key[i].kchar == 1))   // *********************************************** 1
                 Serial.println ("1 is pressed");
           if   (kpd.key[i].stateChanged  && (kpd.key[i].kstate == RELEASED) && (kpd.key[i].kchar == 1))   // *********************************************** 1
                 Serial.println ("1 is released");
        // ______________________________________________________________________________________________________________________________________________________________
             if   (kpd.key[i].stateChanged  && (kpd.key[i].kstate == PRESSED) && (kpd.key[i].kchar == 2))   // *********************************************** 2
                  Serial.println ("2 is pressed");
             if   (kpd.key[i].stateChanged  && (kpd.key[i].kstate == RELEASED) && (kpd.key[i].kchar == 2))   // *********************************************** 2
                Serial.println ("2 is released");
                   if   (kpd.key[i].stateChanged  && (kpd.key[i].kstate == PRESSED) && (kpd.key[i].kchar == 3))   // *********************************************** 3
                 Serial.println ("3 is pressed");
                       if   (kpd.key[i].stateChanged  && (kpd.key[i].kstate == RELEASED) && (kpd.key[i].kchar == 3))   // *********************************************** 3
                Serial.println ("3 is released");
}  // End loop
i have used 1N4007 diode in matrix circuit.
when button1 is pressed ,it is giving right output in serial monitor,,(1 is pressed),,
but when 2 is presssed , it is giving (2 is pressed) & (3 is pressed)
and when 3 is presssed , it is also giving (2 is pressed) & (3 is pressed)
is it related to ghost keys?????/
please check where is fault?????????????????????????//////
What model Arduino are you using?
On an Arduino UNO, when you use Serial you can't also use Pin 0 (RX) and Pin 1 (TX) for digital I/O. Pick other pins, like I did.
When you have 49 keys it makes no sense to use a separate 'if' for every key. You can display the key number just like any other variable.
#include <Keypad.h>
  {1, 2, 3, 4, 5, 6, 7},
  {8, 9, 10, 11, 12, 13, 14},
  {15, 16, 17, 18, 19, 20, 21},
  {22, 23, 24, 25, 26, 27, 28},
  {29, 30, 31, 32, 33, 34, 35},
  {36, 37, 38, 39, 40, 41, 42},
  {43, 44, 45, 46, 47, 48, 49}
byte colPins[COLS] = {9, 10, A2, A0, A1, A4, A5}; //connect to the column pinouts of the kpd
  if (kpd.getKeys())
    for (int i = 0; i < LIST_MAX ; i++)
      switch (kpd.key[i].kstate)
        case PRESSED:
          Serial.print((unsigned int) kpd.key[i].kchar);
          Serial.println (" is PRESSED");
        case RELEASED:
          Serial.println (" is RELEASED");
        case IDLE:
        case HOLD:
}  // End loop()
thank you sir ,,,
sorry for late post,,
i have tried this code to display my pressed button number
 #include <Keypad.h>
const byte ROWS = 6; //four rows
const byte COLS = 8; //three columns             // tested ok display Key number
{1,2,3,4,5,6,7,8},
{9,10,11,12,13,14,15,16},
{17,18,19,20,21,22,23,24},
{25,26,27,28,29,30,31,32},
{33,34,35,36,37,38,39,40},                 //  8 x 6
{41,42,43,44,45,46,47,48},
byte rowPins[ROWS] = {1, 0, 4, 5, 6, 7 }; //connect to the row pinouts of the kpd
byte colPins[COLS] = { 8, 9,  14, 15, 18, 19, 20, 21}; //connect to the column pinouts of the kpd
    if (kpd.getKeys())
        for (int i=0; i<LIST_MAX; i++)   // Scan the whole key list.
            if ((kpd.key[i].stateChanged ) && (kpd.key[i].kstate == PRESSED))  // Only find keys that have changed state.
              int myKey = (kpd.key[i].kchar);
                Serial.print(myKey);       //  kpd.key[i].kchar
so as my post title ,i want to do my own functioning in my this project.
please attention,,,
my matrix is 6x8 . i am using 1&0 pins in matrix,No problem all pins are working fine.
i can not use a single block of functions for key1 to key48. i am going to tell why?
actually i have 5 blocks of funtions to perform from differernts groups of keys.
all blocks are differents.
blocks are for example
   {   Block1(chan1, P1 + myKey, Vel1)}
 {   Block2(chan2, P2 + myKey, Vel2)}
 {   Block3(  y+newKey;)}
 {   Block4(chan++;)}
{   Block5(Vel++;)}
i want to use keys1 tokey17 for Block1, myKey is key number ,that should be used in Block1
---(key18 to key32) should be used for Block2. myKey should be alos used Block2
Block3 should be perform by combination of two keys,.this is different thing, i want to done it by hold key33 and pressing any key between 1 to 32. here is a variable newKey in this block. for this block(newKey should be=pressed second key number (1-32) after hold key33 ,,not use hold key number for "newKey")
Block4 should be perform ,when only key33 is pressed..
Block5 should be perform ,when only key34 is pressed..
other keys , i will use other different blocks..
i hope you uderstand my request please tell me,, what code to write in void loop ();
Or give any hints
thanks to read,,,,,,,,,,,,,,,,,,,,
